Tried it doesn't work at all.
Ah yes, JimStar the way transform node is set up now you can't assign individual float/int nodes to each scale/rotate/translate values.
OctaneRender™ for Blender 1.55 - 4.10 beta Win [OBSOLETE]
- RealityFox
When you change the X value in the full transform node, did you make sure to put it like .2 or .3? Rather than 1 or 3 or 4 etc. The increments need to be below 1. Doing it with full numbers just causes the environment to spin in 360.
AMD-1100T 6 core, GTX-590 & GTX-480 1.5GB, 16GB 1600MHz RAM, 1TB WD 6GB/s, Win7 64bit, Blender 2.68a for Octane 2.2, Octane 1.20, Blender/Octane Server 2.2
Ok. Found the answer.RealityFox wrote:When you change the X value in the full transform node, did you make sure to put it like .2 or .3? Rather than 1 or 3 or 4 etc. The increments need to be below 1. Doing it with full numbers just causes the environment to spin in 360.
No idea why this in the translation and not rotation node. Makes no sense.
Hello,
I have a new bug with octane. It works before and i don't know what happens...
One unique frame render well, but in animation render, octane render frame 1 but crash at frame 2.
The bug is when animation mode is on FULL. It works when animation mode is camera only.
Thanks for help or advice !
Blender Octane Edition - 1.55 - 4.10 beta (2.70)
Windows 7
The mesh tabouret has no problem, and i don't understand this bug that crash octane. When i render frame 2 not in animation, it works well.Octane: ERROR loading mesh. Server response:
Can't connect node 'tabouret' (NT_MAT_GLOSSY, 00000000384F51F0) to static pin 'geometry' (P_GEOMETRY, type PT_GEOMETRY) of node 'tabouret__part___m__' (NT_MAT_MAP, 00000000060E0C20)
Windows 7
blender 2.49 - Octane pre-Beta2.3v5 - NVIDIA GeForce GTX 260 - cudatoolkit_3.2.16_win_32 - driver
260.99_desktop_winxp_32bit_international_whql - windows xp - 3.25 Go RAM
As an image used for environment is a 2D surface wrapped around a sphere, it makes sense imho. It is much more accurate an useful to use Translate X and translate Y to move the texture.No idea why this in the translation and not rotation node. Makes no sense.
This way, knowing your resolution, you can easily move your texture of a certain amount of pixels if required.
If you had a Rotation cursor instead, you would have to use sin or cos to calculate an approximative value !
Guys, I have stuck with some issue and I can't find the answer: what should I do before export to alembic for this additional inputs to appear?
I've never thought about it, but now I've found out that can't find out why some exports generate this inputs and others don't...
I also can't find an input to adjust the aperture value for the alembic scene (I remember, that it was possible earlier).
It it me who does something wrong, or it is the new normal behaviour of the exporter?
Yeah, been waiting for 2.0 update. Need region border
