OctaneRender™ Standalone 1.54
blobbybarack
We have been able to reproduce a similar issue with freezes while batch rendering. The issue should be solved in the next release.
Are you talking about animation batch rendering ? 8-) ;) :D
smicha
kavorka wrote:So far on two separate computers (with different hardware) with 2 different animations (both of which had no problems in 1.53) I have gotten Octane to become unresponsive. Sometimes its after a couple frames, sometimes after a couple hours or not at all.
I've just encountered the same problem.
kavorka
I am using the render imported animation script, not batch render. Is it the same bug?
abstrax
kavorka wrote:I am using the render imported animation script, not batch render. Is it the same bug?
The problem affects all Lua scripts using octane.render.start(). A change made in 1.54 (to fix another issue) can result in deadlocks. The new problem is fixed and we try to get a new build out as soon as possible next week.
kavorka
Thanks guys :)
kavorka
New bug.
We just noticed that sometimes when we click stop render, it ends up taking the image you have now, and saving it over everything you already rendered and adds all the frames that weren't completed yet. Luckily we were just doing a test animation, but it replaced about 200 frames of animation.
abstrax
kavorka wrote:New bug.
Hmm, couldn't reproduce the issue here. When I click on "Stop render", it just stops rendering. What exactly do we have to do?
kavorka
I'm not exactly sure. It only happened once, so it might have been a number of things. It hasnt happened since, but we have been backing up files regularly.
kissa1375
Hello, i put Octane Render 1.54.2 and i can not find a "preview" in settings for inregistrate images (as we hade in Octane Render 1.00) . Could you please tell me where can i find it .Thanck you
kissa1375
there is octane settings with no preveiw
