OctaneRender™ Standalone 1.29
Synthercat
Errrr I had to use specular didn't I?
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
roeland
Yes, either a specular (for glass and such) or a diffuse with transmission enabled.
Roeland
gardeler
Turntable freeze.
I'm trying to render a turntable in 1.29. Each frame takes about 10 min, and I have set it to do a 360 over a 100 frames. I start it to run over night, but when I return to my desk the day after, the render has stopped in the middle of a frame. (frame 13). There is no feedback in the terminal of any kind. Has anybody experienced something similar?
I have recently switched to linux, so I do not have any program for monitoring gpu performance. Any recomendations similar to gpuZ?
I suspected that it might be something simple, like linux shutting down the gpu's when going into screensaver or something. But I have turned off everything I could find.
I will retry tonight, so any tips and tricks are welcome!
Im running Ubuntu 13.04, i7-3930K, 32gb ram and 2xTitans.
gabrielefx
what about a 360 degrees Lua animation script to create VR animations?
gardeler
gardeler wrote:Turntable freeze.
Just moved the scene to a windows box, and the first thing I noticed was a 20% speed increase! (from 10 min to 8) It has the same hardware as the linux box, except the motherboard. Is there really a that big speed difference between linux and windows? I checked my overclock settings and everything is set to default for the titans. And I do not have any OC program on linux, so I assume they run at the same settings. Interesting...!
Synthercat
That's weird cause If can can find my benchmarks I remember that Windows764 vs Linux-64 had different results
Linux was something like 1-4% slower BUT it did load the file A LOT faster.
I only use linux now
felipezumaeta
I'm getting this message when I try to download the Windows Zip file:
Gateway Anti-Virus Alert
This request is blocked by the SonicWALL Anti-Spyware Service. Name: Banload.PAV Installer (Trojan)
gardeler
Synthercat wrote:That's weird cause If can can find my benchmarks I remember that Windows764 vs Linux-64 had different results
Yes, it sounds strange, I agree. Our sysadmin, (very linux savvy), is sick today. When he is back, I'll ask him to take a look at the linux box to see if he can find a reason for it to be slower.
boris
Menu: Script > Render Imported Animation
Is this the way to get an image sequence out of Octane?
The only option there is PNG 8bit?
If I select alpha option in RenderTarget plus "Keep Environment" the rendered images do NOT KEEP the environment.
cheers
boris
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder :))
smicha
boris wrote:If I select alpha option in RenderTarget plus "Keep Environment" the rendered images do NOT KEEP the environment.
I have the same issue.
As I mentioned some time ago, the lock button (the padlock) is not working - when I maximize the preview window it is being deactivated (I use dual monitor setup).
