Beta 0.72 / 0.79 (SDK 1.20) - Obsolete
decade wrote:Got to say, now the installer is fixed up, this seems to be a really solid release.
Problem with using a core all the time is gone, everything seems to work well, priority settings for the GPU work really well (gret for people like me with a single card).
Congratulations.
i hope that we resolved render problems. I don't like to release to much. This confusing for people. I'm testing also on a ordinary notebook and performance is acceptable with priority option.
many thanks, enjoy it
mattfrodsham
I'm getting some fairly consistent crashing in .69b (Mac) when switching from my docked Picture Viewer back to my Viewport after rendering (so far they have been animation). I wonder if this update will help once it is ready for mac?
cheers!
Windows 8.1 / 4xGTX980 / C4D R18
Method
Nice. But after render the image to the browser, then I can not touch a material, otherwise Cinema crashes
ASUS P6X58D-E / Nvidia GeForce GTX 780 / 24GB Ram (DDR3) / i7 950 (OC4.2Ghz-without HT) / Windows 7 x64 / and million cooling fans :)
VFX/CGI, Animation for documentary movies, Music videos, Products renderings, Advertising....3D/2D (small production)
mattfrodsham: Yes it must be exactly same as PC release. I have fixed lot of crash points
Method: It's not normal. I must be to fix this kind of problems. It's consistent for all scenes? What is your c4d version?
cfrank78
Played with it for a while! Works pretty stable. Sometimes crashes, when having a larger szene with many updated objects for animation. Quite good, but not perfect. Still much slower than a compared MAX Szene with Octane Max Plugin!
3D Connection device still not working correctly together like in Max.
Kind regards Chris!
Method wrote:Nice. But after render the image to the browser, then I can not touch a material, otherwise Cinema crashes
yes, you are right. Sometimes this occurs, i'm fixing and i'm going to upload a patch.
Method
Perfect!Thank you! ;)
Fixed now ;)
Method
Works now ;) Thanks!
artdude12
I am having a possible memory leak or something. I installed the latest beta (0.72B).
It worked OK at first. Then after a little while, c4d locked up and I got the spinning blue ring (Windows). Had to force quit. After re-starting cinema I noticed that the Octane Convert Materials tab was missing. Octane Live Render tab is still working. When using Octane as my renderer with the Picture Viewer, everything seems OK. I did a 90 frame test animation and it worked great. The scene file was the Rainasawrus Earphones.
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
