OctaneRender® for Maya® beta 2.58b [OBSOLETE]
thomaslee1312
Slimshader wrote:Yeah that is really interesting!
In the screen shots all those icons on the renderview were greyed out.
I looked into it and it usually only seems to happen when I start, stop or pause renders from the octane shelf.
It also happens if i start a render from the render view menu IPR>IPR Render > Camera or if I refresh the render by pressing the IPR button instead of the green refresh button.
I couldn't stop the ipr so I closed the render view and got this error:
// Error: line 1: Object 'pauseIprButton' not found. //
Then it crashes.
https://dl.dropbox.com/u/85554647/report%20wed3.zip
I also can not use the IRP pause button in the render view sometime. In normal case, the buttons can be used. Sometimes it turns to be gray. But I can still use the Pause and Stop button in Octane render shelf to control the render. I am not sure if you are the same problem.
Found the reason of this crash... Will be fixed soon...;)
Slimshader
Kewl! :)
Almost finished, but it is already 0:35AM here, so I will release tomorrow. I want to finish adding of the "batch command mode render" support, the first step to DR...;)
Next version HERE.
Return to “Autodesk Maya”
