The temperature is not that huge, if you care about air flows of box.Amplitude wrote:YoonKyung do you run that beast in a temperature controlled room? (i.e. a deep freezer)
I'm reading everywhere on the web that because these babies are getting so hot so quickly, nvidia does not advise to stack them without leaving a 2 slot space between each card...
And they are talking about SLI setups (2, 3 cards) , but 7 ! How is the rig holding up?
I am ready for multi-GPU test.
Win7 64 | 2x XEON | 12GB | 8x GTX580
Gigabyte 4x pci-e x16 dual slot mobo ready for 6 core cpu
http://www.gigabyte.us/Products/Motherb ... A-X58A-UD9
Just the thing for 4x EVGA watercooled GTX480
http://www.evga.com/products/moreInfo.a ... s%20Family
send your donations and lottery prizes to me
Octane v1.55
Octane v1.55
The system that ericNV is using is a little different then yours Yoo. I am curious too about the cooling and airflow in that case. I know coolermaster? made a case that fits 4 gtx480's that was especially designed with a front airduct to bring in air to the cards directly. The big one that EVGA keeps bragging about, that broke all the benchmark records, used liquid nitrogen (crazy people). I am not saying that I think your rig will blow up in a ball of fire. Just curious how much heat it will produce and how well it cools. Mainly because I might see if my work will invest in something along these lines.
System 1: EVGA gtx470 1280Mb and MSI gtx470 1280 in Cubix Xpander for Octane, AMD 945, 4Gb Ram
All systems are at stock speeds and settings.
Basically GPUs has its own heat sink system, so if you care the air flow of the PC case, what ever it would be, you can keep GPUs cool.havensole wrote:The system that ericNV is using is a little different then yours Yoo. I am curious too about the cooling and airflow in that case. I know coolermaster? made a case that fits 4 gtx480's that was especially designed with a front airduct to bring in air to the cards directly. The big one that EVGA keeps bragging about, that broke all the benchmark records, used liquid nitrogen (crazy people). I am not saying that I think your rig will blow up in a ball of fire. Just curious how much heat it will produce and how well it cools. Mainly because I might see if my work will invest in something along these lines.
