Version 3.00 - Alpha10.1 (30.04.2016)
Josef wrote:sorry if this is mentioned before , but often when connecting a new image node to a material channel , c4d hard crashes.
hard crash?
Josef
hard crash?
meant c4d will stop working (the normal windows pop-up) , it's different from the one usually create a bug report file
Josef wrote:
hard crash?
Sorry this is not giving any idea to start. You should describe that as i asked in first page with red letters. Thanks!
cfrank78
I am on a huge project with volumetrics with complex textures. Region render is a must have this time. Any Idea when V3 Alpha 9 comes? You said yesterday and i checked every hour but still no release. Any scedule when you release? THX!
Chris!
bertritude
hI guys,
thanks for the .vdb tricks.
I tried to use the cloud package and it works only with the .vdb folder with a path without special characters ("é,è" in particular).
If I put it in my library, it don't work.
did you try to use it from your library ?
Bertrand
cfrank78 wrote:I am on a huge project with volumetrics with complex textures. Region render is a must have this time. Any Idea when V3 Alpha 9 comes? You said yesterday and i checked every hour but still no release. Any scedule when you release? THX!
Chris!
RR has problems on A9. I'll disable it if i release a version.
cfrank78
aoktar wrote:
lucioing wrote:Hi Ahmet!
Thank you for you great job, a always...
What about render region? It seems it doesn't works... If I do select a region, in LV the rendering it is done on ALL window...
L.
It's not working on A6 SDK. I'll release A9 on monday.
This message sounded like its an SDK error, which is with V9 fixed and that you will release V9 on monday! Soory......really my bad that i asumed that i will have a working region render Version on monday :-P! Good luck with the release!
Chris!
bertritude wrote:hI guys,
Bertrand
Can you explain how do you use it?
Btw integration for A9 is taking much more time than expected. Lot of small revisions and code tide up is required before release.
Newermax
Dear Ahmet! A small request. In the "Alpha 6.3" does not work animation texture. Please make sure it is working properly in the next version. Thank you.
Newermax wrote:Dear Ahmet! A small request. In the "Alpha 6.3" does not work animation texture. Please make sure it is working properly in the next version. Thank you.
try on fully english chars also don't use '-é etc.. It's fixed.
