OctaneRender 3 for Revit [OBSOLETE]
Seekerfinder
Ok, just to recap then, Paul - 3.6.4 is definitely newer than 3.6.5.46?
Seeker
3.6.4.47 is definitely newer than 3.6.5.46. The last digit (47) which is incremented each release (if the plugin code was changed in that release).
Seekerfinder
face_off wrote:3.6.4.47 is definitely newer than 3.6.5.46. The last digit (47) which is incremented each release (if the plugin code was changed in that release).
Thanks for clarifying, Paul.
I have updated the installers at the top of this thread with a test release as follows:
3.7.0.49
- Compiled with Octane 3.07 TEST 4. See viewtopic.php?f=33&t=62636 for details.
- Changed "Linear" projection to "XYZ to UVW" to match Octane Standalone
- Added the new UVW Transform texture node from Octane 3.07
- Added the new Baking Texture node from Octane 3.07
- Revit 2018 now provides the actual full texturemap names used in Revit Materials, so these should now correctly be converted when you create an Octane material from a Revit material
I have updated the TEST version installer at the top of this thread with:
3.7.0.50
- Compiled with Octane 3.07 TEST 6
Cosoli
I can't render after I installed "Octane 3.07 TEST 6" :o
It showed this issue and stopped
What version of Revit are you running pls?
Cosoli
2018
Tks. :D
2018
Pls install Revit 2018.1. That should resolve your issue.
Cosoli
face_off wrote:Pls install Revit 2018.1. That should resolve your issue.
It works :D
tks!
Return to “Autodesk Revit”
