OctaneRender™ 2020.1 XB1 [superseded by 2020.1 XB2]
Lewis
Hi DEVs,
First of all thanks for BUG fixes form XB1 (both of my bugs are fixed now :))
Although I have some questions about Hosek-Eilkie Sun system,
For better explanation I'm sending short video to show the problem/confusion so maybe someone from DEVs could jump in and explain what is going on there, why does new sun model so drastically change reflections in my scene.
Is this new behavior correct ?
Here is the video and ORBX scene and video.
Thanks and Happy NY :).
RTX_Velvet_Glass_BUG.rar
ORBX scene file
(21.52 MiB) Downloaded 349 times
Octane2020_XB2_Hosek-Wilkie_daylight_video.rar
Short Video with explanation
(33.21 MiB) Downloaded 433 times
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
karl
Lewis wrote:Hi DEVs,
Hi Lewis,
Thanks for the explanation of the difference you're seeing - the scene and video are really helpful. I think the result you're seeing is correct. The reflection is dim, but visible on a black background. On a bright sky background the reflection is overwhelmed by the brightness of the sky. This doesn't appear to be related to the daylight model chosen - I can get the same reflection effect using the Octane daylight model if I adjust the ground angles so that the relevant part of the sky is black. I can also see the reflection by changing the glass railing to a diffuse black material.
Lewis
Thanks for answer karu, I suspected it might be ok due hemisphere vs full sphere but i just wasn't sure. Thanks for explanation/confirmation.
Lewis
Skype - lewis3d
ICQ - 7128177
andrey.krivulya
mojave wrote:
Hi @andrey.krivulya
Your issue has been fixed. Unfortunately it didn't make it into 2020.1 XB2 but it will be included in the next build.
For now just so you are aware this was an issue related to autofocus, so disabling it from your scene should not fix it completely but mitigate it significantly.
Thank you.
Hi, @mojave
Thank you for this fix.
Windows 11 Pro / Intel Core Ultra 9 285HX / 96GB DDR5 / RTX 5090 Laptop 24GB / 4TB SSD / MSI Titan 18 HX AI
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
mojave
funk wrote:
funk wrote:OTOY team, can you please post a sample file for those Vectron Volume screenshots? I can't figure out how its done.
I know you guys are probably really busy, but is it possible to get a sample file showing us how Vectron Volumes are created?
We have updated the section regarding vectron volumes in the initial post with Lua script you can use as reference.
funk
Thanks. I don't think anyone could have come up with this without an example script :) I hope this process will be simplified with a built in node that converts vectrons to volumes.
I don't even think my plugin (for modo) supports lua scripts
jimho
karu wrote:
SSmolak wrote:
osiosiosi wrote:Question ...
Does NVlink work with 4 cards? Meaning a pool of 2 x 2 with total 22GB memory avaiable?
Can anybody confirm?
I can confirm that NVlink memory pooling doesn't work even for one pair at the moment. It probably works only for Quadro and Titan RTX. It doesn't work for any other Geforce card including 2080Ti.
If your scene extend memory of one card and you have disabled Out Of Core - Octane render will fail with out of memory error.
We have identified the cause of this issue and are working towards a fix. It should be available in a future build of 2020.1 (likely not XB2 though), and a future build of 2019.1.
Regarding 4 cards, currently we only support memory pooling with pairs of cards (but you can have multiple pairs). So you could pool memory between cards 1 & 2 and between cards 3 & 4, but you can't have a single pool with cards 1, 2, 3 & 4 all together.
Dear Karu,
It seems only one pair of 2080ti sli is allowed by nvidia, the second pair does not appear in the nvidia control panel at the same time with the first pair,
does that mean octane may jump over the nvidia control panel to active the both nvlinks?
only one pair of sli is actived at the same time
many thanks,
Jim
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
mojave
jimho wrote: It seems only one pair of 2080ti sli is allowed by nvidia, the second pair does not appear in the nvidia control panel at the same time with the first pair,
NVidia drivers at the time of writing this allow just a single pair of NVlinked cards for GeForce series, more than one pair is allowed just for Quadro cards.
jimho
roy_orengo
Thank you very much for this upgrade!
I really appreciate the procedural textures. I 'm sure this is the future.
I would like to ask you if the folder inside the live DB named OTOY (With procedurals textures and absolute textures subfolders) are made by Octane Team and if there are other inside the Live Db or only there made by YOU.
Thank you again, and I hope you will develop more procedural, osl and procedural options to create materials fully without photo from reality.
best regards,
Roy
