Beta 0.72 / 0.79 (SDK 1.20) - Obsolete
mattfrodsham wrote:Let me clean my plugin folder up and do some tests later today, I'll let you know if I find out what causes it or if it continues after removing everything :)
ok, i can test if you let me know the your list
dinf
Ahmet I have still no success to get .79B to work.
I copied the whole C4D folder, deleted all not-C4D based files (plugins, scripts, browser content) until it was like pure install.
Then I installed 0.79B. The effect was the same as written in the PM: octane failed to show the complete geometry, lacking most of it. .76 is still working good, but I need some of the new features as rendering 16/32 floating images from picture viewer.
I did not switch on the update geometries option because the scene nearly couldn't be handled anymore. Every click on an option takes up to a minute till it responses. Under this circumstances I tried different priorities of the device, I have one card for all, wich does not change the slow reaction. Btw: I had this two wired responses since 0.77.
So it does not depend on any installed plugins. What else can I try?
| Win 10 | 64 GB RAM | AMD 5900X | RTX 3080 12 GB| C4D 21| C4Doctane v2022.1.1|
dinf wrote:Ahmet I have still no success to get .79B to work.
0.79B has lot of internal changes. You can think as a testing release.
Because of this somethings can has problem. Also i have found a problem with render instances and zero scale while update geometries is activated in rendering.
I'm working on this. I hope to fix lot of things and release soon(in 1-2 days)
mattfrodsham
To confirm my render queue crashes after the first job even with no other plugins in my folder
Windows 8.1 / 4xGTX980 / C4D R18
dinf
I'm looking forward to it!
cfrank78
In my case Hot4D crashed Octane. I removed the plugin and it crashed again, until i realised that i had to delete the dll files of hot4d from the root folder too!
No crashes here now since 6 days using 079b!
mattfrodsham
The only thing (I think) that I left were the vray libs in the C4D application package necessary for the plugin to run. I don't have hot4d,
For reference my usual list is:
ChamferMaker
CADeformerPack
Flatten
KyamaSlide
SteadyBake
True Symmetry
Vray
But none are in use in the scenes that crash, and I already tried removing them from my plugins folder. Maybe that info helps?
mattfrodsham wrote:The only thing (I think) that I left were the vray libs in the C4D application package necessary for the plugin to run. I don't have hot4d,
to loading any confusing plugin that is enough to crash.
dinf
FYI: there are no left DLLs in my test-installation.
I'll try the render queue crash wich I had also later on with the clean Cinema version.
buzby
Ahmet, I am trying to get a round IES spotlight to work in the plugin. I know it was possible in the standalone, http://www.youtube.com/watch?v=Tedj2lEK ... B&index=12 is this working in the plugin?
Asrock z77 extreme9 | Intel i7 3770K 3.5 | Win 7 64 bit | (1) EVGA Titan| 30" Apple Cinema Display | LEPA G1600W PSU | 16GB Ram | Storm Trooper Case |
Autodesk Inventor>3DS Max >Cinema 4D R14 Broadcast
