OctaneRender 3 for Rhino (OBSOLETE)
I have a monitor with 1920x1080 resolution. I don't use 4k
Can you try setting your Windows font scale to 100% and tell me if that resolves your problem?
fabrizio_s
the font size is already 100%
bye
I am currently working on the Rhino6 font scaling issues, and hope to have a fix by the end of next week. If all goes well, I will release a subscription version with the fix then too. In the meantime, pls revert back to Rhino5 if you wish to use the Octane plugin.
fabrizio_s
thank you very much Paul!
I have posted a new TEST build at the top of this thread for Rhino6.
3.08.1.92
- Compiled with Octane 3.08.1
- Experimental build to try to address issues with the plugin UI on 4k monitors
- Fixes to material Previews - but still not quite right
fabrizio_s
Hi Paul, this version is not for subscription...right?
Correct - I do only release STABLE plugin versions (not TEST versions) for the Subscription version of the plugin.
fabrizio_s
ok thank you
bye
Refracty
How is the progress with the material preview Paul?
What are the next milestones for this topic?
Thank you!
I don't understand what you are referring to. Is it specifically the Rhino6 previews? If so, there was a note on this in the latest TEST release.
Return to “Rhinoceros 3D”
