Hi used2bgordy,
what's your version? Kernels should not jump DL, i remember it's fixed. if i'm wrong, i'll check it.
2-I'll look for disabling "multilayer file" option.
3-MatId, i'll report this. But we are waiting a revision for objectID's.
4-Lights are also objects. You should set opacity=0
5-I have ignored "maxsamples" for passes. I'm going to add.
6-Do you mean for ex. displacement on cubes?
Hi momade,
Only textures can work on background object atm. I'll look for it. But this is simple compositing on plugin, has not any effect on renderer.
Version 2.12.2 - final (updated on 18.11.14)
- used2bgordy
We work on 2.12.1 and it jumps from PathTracing to Direct. We experienced it in all stations.
6. well, cubular objects. Check att
- Attachments
- Displacement weirdness
- weird.jpg (39.11 KiB) Viewed 5058 times
- used2bgordy
Opacity on lights also turns off its reflecion visibility. Is there a way to keep it? Opacity to 0 and still keep them visible in reflective objects?
Artur
Artur
no way. Because Octane has not any light, all is the objects with emissive materials. We can ask to developers for a improvement.used2bgordy wrote:Opacity on lights also turns off its reflecion visibility. Is there a way to keep it? Opacity to 0 and still keep them visible in reflective objects?
Artur
For kernel, i couldn't produce here. Can you send me two simple scene which can reproduce this problem? Also one scene for your displacement. Thanks
cannot see itused2bgordy wrote:File attached.
Artur
- used2bgordy
Sorry, I had a nasty crash. Here you go
Artur
Artur
- Attachments
- test.zip
- (136.23 KiB) Downloaded 274 times
- shawnfrueh
Hey Aoktar, Can we get Octane to recognize when a particle emitter is not visible for render? Right now If a particle is in the scene, visible or not it is still displayed.
how are you using particle?shawnfrueh wrote:Hey Aoktar, Can we get Octane to recognize when a particle emitter is not visible for render? Right now If a particle is in the scene, visible or not it is still displayed.
don't use with octane subdivision. I think it doesn't take virtual face normals. Use c4d geometry except this.used2bgordy wrote:Sorry, I had a nasty crash. Here you go
Artur
