I am doing fine with 2.6.4 (Sep 16 2014), no problems with getting stuck.
I would change Projection node arrow color because it is not visible on node editor background.
OctaneRender™ for LightWave™ 2.0 DAILY BUILD
- BorisGoreta
- Contact:
19 x NVIDIA GTX http://www.borisgoreta.com
Sorry Boris, I can't change the custom node connections colors. The LW SDK set the colors itself (I don't know how) and I can't change it.BorisGoreta wrote: I would change Projection node arrow color because it is not visible on node editor background.
(I was wrong, 2.6.4 works fine, I cannot delete my messages so I edit them like this to avoid misunderstandings)
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun
BTW, what temperatures are you people getting?
My GTX690 gets 85 C and GTX Titan Black 83 C, are those too high?
If so, how can I force the fans to increase RPM?
- BorisGoreta
- Contact:
That sounds about right, TITAN and TITAN black around 83 degrees here too. You cuuld download EVGA precision software and tune fan speed, but I wouldn't recommend that because it is too noisy then. You should let your cards render at their optimal clock/temp/fan speed. They adjust themselves accordingly. My fans run at 50%.
ThanksBorisGoreta wrote:That sounds about right, TITAN and TITAN black around 83 degrees here too. You cuuld download EVGA precision software and tune fan speed, but I wouldn't recommend that because it is too noisy then. You should let your cards render at their optimal clock/temp/fan speed. They adjust themselves accordingly. My fans run at 50%.
My Titan Black: 2580rpm (graph max 6000), power 73% GPU temp now 86 C
so it sounds normal
I would like to get more cooling even if it makes some noise as it is getting warm here when two cards are heating the room air
Juanjo, it seems everything is fine, now the 2.6.4 rendered that same scene without problems.
I am VERY sorry for this hassle
It seems my system was messed up, nothing wrong with Octane.
Again, I am really sorry.
If you can, please delete the posts about this false alarm, I cannot delete my posts so I edited them to avoid misunderstandings)
That might be good but I should have FIRST tried to reboot before I caused you extra work (testing)juanjgon wrote:No problem. Sometimes the system has problems with the GPUs that can be fixed if you reboot the computer. I should add this tip to the docs
I know that 90% of the problems are fixed by reboot and also I noticed that I had not rebooted my 3D workstation for 2 weeks so...
