Beta 2.2 RC1: Maya exporter plugin (unofficial)
bazuka
if u have probl with shader and settings in octane, thats the octane bug (2.3v5) best to return to some previous ver
u can also check here
http://www.refractivesoftware.com/forum ... =28&t=4100
Maya 2009 x64 & Maya 2011 x64
Windows 7 x64 & Windows XP x64
2x Quad Core Q6600, 8gb, Nvidia Gtx 260 & Gtx 460
tharr
I see. I will go to a older version.
Processor: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz (8 CPUs), ~3.3GHz,
Video Card: NVIDIA GeForce GTX 480
Memory: 6144MB RAM
Operating System: Windows 7 Professional 64-bit
radiance
bazuka -> can you explain what the issue is ?
there should'nt be any issues on the exporter side between 2.3 v5 and older, or am i missing something ?
Radiance
bazuka
well this is the probl
if i already have exported scene to octane and i have setup the shaders and other stuff, when i lets say move obj inside maya and i try to render again i get everything inside octane reset to defaults??? (shaders gone, sun direction, etc...)
i also tried with max and xsi exporter and i got the same thing, so must be octane then ;)
cheers
radiance
Ok,
I'll check it out.
Radiance
tharr
I think it has something to do with the [Save] feature. If you try going [Save as] and overwrite that .osc file it works for me. Just the heads up, that might be the problem.
Memory: 6144MB RAM
tharr
Hi bazuka,
Just wondering with rendering Animation frame by frame, is it possible to get AF (Low Depth of Field) in everyframe via the Animation?
I seem to have to keep clicking the image of where I want the AF to go, for everyshot.
Memory: 6144MB RAM
tharr
It's for a client production. Are you going to answer?
Memory: 6144MB RAM
bazuka
yes, i was out...
well im not sure i can do that from the script (maya)
i can export from maya only the maya2octane GUI settings, for now
im not sure if we r talking about same thing, u have in script the 'aperture' thats the DOF all u need to point the camera focus on some model and set the aperture value...
would be best to send me some sample or scene...
cheers
tharr
Sorry about that bazuka. I would send the scene though all togther with the (.mtl .obj .ocs) it's over 150MB.
I'll send you a picture of the shot I rendered out with the AF (Depth of Field) tool. If you see in that picture, it's got it on, though when I save over the .ocs file it happeneds to no focus on her again. It does not even focus and it the whole scene goes blurred. Is there a way that for every frame it can focus on her without me clicking it everytime?
400 Frames at 4000samples with clicking is too hard :P
tharr
Memory: 6144MB RAM
Return to “Autodesk Maya”
