OctaneRender 3 for DAZ Studio [TEST and STABLE] [OBSOLETE]
Moderator: BK
Sorel
Thank you Paul!
Laticis
Thank you for the update.
DrHemulen
Thanks!
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
SiliconAya
Anyone had any luck with the new Bokeh feature(s)? I've been messing around with the new settings in the camera, but they don't seem to do anything for me, they don't even restart the render like most other camera settings do (not sure if they should or not though).
Can I suggest you export your scene to Standalone via ORBX, then in Standalone test the bokeh settings - and if the DazStudio plugin is not producing the same results, let me know pls.
SiliconAya
face_off wrote:Can I suggest you export your scene to Standalone via ORBX, then in Standalone test the bokeh settings - and if the DazStudio plugin is not producing the same results, let me know pls.
Ok, I exported to Standalone and the bokeh settings do restart the render when you make changes and I can actually see the results of changing the settings. So it looks like the bokeh settings in the Daz plugin don't do anything at the moment.
Can you prove screenshots showing the effect of different bokeh effects you are getting pls?
SiliconAya
Should the Boken Edge setting be Boken Rotation? As those settings don't match between the two.
Plugin settings
Plugin settings
Plugin render
Plugin render
Standalone render
Standalone render
Standalone settings
Standalone settings
Thanks for the info. It looks like the DAZStudio Bokeh controls are not correctly linking to the Octane Bokeh pins. I will fix this in the next release.
Return to “DAZ Studio”
