OctaneRender 3 for Modo [OBSOLETE]
Tharso
click to save render the windows popup open, go to explore before click save and close the windows, modo crashs. Always
I could not replicate this problem, and there have been no other reports of it. Can you pls provide the information requested at the top of this thread (plugin version number, OS, Modo version). Are there any special characters in the foldername which you are saving it? Which format are you saving as? Have you tried deleting your ModoXXX.cfg file?
Tharso
humn.. windows 10, last version of modo, octane, new new config and I formated my computer 1 week ago. Very strange u cant replicate that, because I have the same problem at my home and my office. I will try explain again. Click to save the octane image, the window shows up and then try to do another thing in windows before save. Always crash here with the last four version or more. If I do the save without leaving the window dont crash.
I'm sorry - but your explanation is very confusing. Can you provide screenshots showing what you are doing pls?
Dmi3ryd
Hello, Paul.
When make direction constrain from camera to selected locator and try to change position, сamera is not updated in viewport.
Is't it possible to make it more interactive? I mean, I need each time refresh my scene.
Thanks.
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
v1adut
face_off wrote:
I saw added support for substance material, I am on modo 10.2 how can I make it work ?
It does not load the textures from the material as modo does.
Hi - Substance texture support needs a change to the Substance plugin, which the Substance devs are currently working on. Once this is done, I will post a tutorial explaining how it works. Sorry for the confusion on this.
Thank you for letting me know Paul, and also for working on application integration.
Can you send me a simple Modo scene which demonstrates this issue pls?
redbeard
I am getting this crash on Modo10.2v1 on Mint18 too. The plugin works fine on Modo902. This appears to be a bug in Modo10.2v1, but I will need to consult with TheFoundry devs to determine the exact problem.
I will update here once I know more.
Hi Paul,
Any update on this issue from the Foundry?
Roy
Hi Roy. TheFoundry have escalated the issue to their dev people, but no news yet.
Visualize
Hey Paul,
Deferred Meshes increase ram usage. Not sure why but thought I'd let you know. Went from 1.3gb used then to 2.2 gb used once I deferred a dense mesh.
Return to “Foundry Modo”
