Version 3.03.3-R1 (11.08.2016)
mesut
since i am a relatively fresh octane-user, i may have misinterpreted things but i had the impression, that in the past, standalone-updates were followed by c4d-plug updates, if not in real-time but a very short period of time later.
now i saw that a new version of the standalone is online since septembrer, 2nd. (3.03.4).
i already downloaded the standalone-update but do hesitate to install, since i use octane only in play with cinema, which has it's most recent plug-version dated august, 11th.
is there no need for an updated plug-in for that?
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
mesut wrote:since i am a relatively fresh octane-user, i may have misinterpreted things but i had the impression, that in the past, standalone-updates were followed by c4d-plug updates, if not in real-time but a very short period of time later.
New update will be done when it's ready. My advice to you is to wait until we make newer release for plugin. Why do you want to intended to use 3.03.4 SA?
Yambo
Dear Ahmet,
A while ago i saw on facebook a new octane4c4d version you featured with some A-B compare feature in the live viewer.
Is it going to be implemented in the next version?
Thanks!
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Yambo wrote:Dear Ahmet,
Thanks!
Yes. First basic version is already added. It will be available on next release.
jeffbriant
Did "Save scene with Assets" get taken out of this 3.03.3 R1? I can't seem to find it in File menu, did it get moved?
2x1080's network rendering to 4x980Ti's
Hi jeffbriant,
The "Save Project with Assets" in the LV menù was an old command and has been removed since the same command from c4d from the File menu works correctly as expected.
mrom
at 3.03.3-R1 I get the please wait...error with LV in R16, when I try to stop the process, it doesn't work, when I quit c4d (I have to), I get a small box with "Wait until export" and then c4d cannot start. I have to kill the process, otherwise I cannot start c4d again.
never had this before, rolling back now.+
it seems (to me), that 3.03.3-R1 is a bit pickier about c4d textures than the previous versions, could that be?
another thing: there's no thumbnails of octane materials, and if I use the save files with assets command for an old file, there is no assets folder in my tex folder..I am beginning to believe that something in my sys is fcked up. works with a new file though.
Yambo
What happend to the A/B compare on V3.03.3-R1?
https://yambo.me
Yambo wrote:Hi,
viewtopic.php?f=85&t=56169
Yambo
Oh sorry,
Any idea if this issue i had is also fixed with this version?
viewtopic.php?f=30&t=56386
https://yambo.me
