Version 3.06.2 - obsolete stable
Terryvfx
aoktar wrote:
Terryvfx wrote:
Studio21 wrote:The list of nodes is getting longish
Time to consider a small search function ;)
+100 to this.
in node editor?
Yes, like using the standard shift+c of Cinema but in the Node Editor.
Steeviekay
I installed the 3.07 now.
Before I rendered a scene Iam working on at the moment in 3.06-
Rendertime in 3.06: 08:48
Rendertime in 3.07: 05:59
BUT It looks extremly different - and I changed nothing, just opened the project and hit render.
There is something with the light... All the Emissive lights seem to be messed up a little bit - is this wanted or should it render like in 3.06 ?
//edit: I think it has something to do with the "Transparent Emission" - on those lights I have to turn it on now (Have a bunch of invisible lights in my scene)
omardex
Greetings.
Aoktar posted a changelog before
- Change: Internal diffuse color changed from gray to black for internal material of Light Tags. It may cause a small amount difference on results of illumination effect.
It appears the plugin have a change in the parameters of the lights
Best Regards.
Omar.
Omar Tavera
Awesome Generalist
omardex.artstation.com
Octane render for c4d but moving more toward standalone with one 980ti
Terryvfx
Steeviekay wrote:I installed the 3.07 now.
Can you post some before and after pictures? the lights are actually as it should be now, before it had a gray diffuse that was making light bounce off of it.
Steeviekay
Jeah right - Iam preppin´my scene right now to make it look the same as with 3.06.
Studio21
Hi ahmet,
Getting crashes each time im trying to access my local DB. no crashes on Live DB,
Just checked back on 3.06.2 local DB works as expected there
Ty,
Guy
Studio21 wrote:Hi ahmet,
Ty,
Guy
Can you check content of it? Maybe somethings are causing crashes from old files. Alternatively delete all files or folder then move back material files partially.
Studio21
I removed all my folders from the Local DB root folder. tried to save a new material in there. it does create the orbx file on the HD but wont let me see it in the Local DB browser, and usually crashes right after
Studio21 wrote:I removed all my folders from the Local DB root folder. tried to save a new material in there. it does create the orbx file on the HD but wont let me see it in the Local DB browser, and usually crashes right after
what's full path of localdb?
Studio21
C:\Octane LocalDB
Best,
Guy
