What if it's a warped mind?Post by Tutor » Thu Jul 16, 2015 12:55 pm
An imaginative mind is a terrible, terrifying and dangerous thing to waste, especially when it comes to sandwiches - mozzarella?
Speaking of food, I actually in the past had restored my failing XP's ATI Radeon card by baking it in the oven...20 minutes @380 degrees, if I recall correctly. So I definitely can appreciate the culinary skills I see there!Can you increase the GPU spacing and GPU/environmental cooling? That way, there would be no taste of dust, unless the wind is blowing against your backside. Know what - all of these calculations have made my temperature rise and given me a voracious appetite. I think that I'll make a cool sandwich (or two or three). Also, I like more bread than mozzarella cheese. I like my cheese thin and cut into a perfect square and sandwiched tightly (as if glued ) between two larger, cooling, and screwed together slices of bread (one wet and the other airy).
I did get an Amfeltec GPU cluster (single adapter, 4-way), and I am now using this for 2 of the Z's. It runs very nice, I am very happy with its performance. It is sturdy as well, almost a little too robust. Heavy with the GPUs, like a 30 lb weight. But no issues at all. I have these 2 cards blowing air outwards to the same side, and they run very cool, however are stock speed. The other 3 on risers on a ad-hoc grill-like stand, fan up blowing air upwards. 2 of these are default OC'd. I like the cluster set up more, but harder to tinker with that, direct plugin to board is less flexible than the cable risers, with are very fluid if I ever examine/move the cards around.
Tutor and all, I am using MSI afterburner, which allows for group tweak of GPU by type, or individual tweak. But the app only gives the option to direct tweak 8 GPUs. In other words, it doesn't let me individually tweak the parameters for 9 and 10. The list only goes from 1-8. And one is the X, which means 7 Z cores are available for individual direct tweak, and 2 are not. (remember, I have 9 Z cores currently recognized and functioning, not 10). It just so happens, however, that when I use group tweak, it affects all. I do not know if it is because the app sends a mass message to all of the Z's, or it just so happens that in my case 1/2 a Z is among the 1-8 listed on MSI Afterburner's control panel for direct voltage/Fan/etc control, and then the other 1/2 is listed as 9 and 10. It does, however, let me view all 10 GPU cores in the live graph area, so I can monitor all 10 very effectively.
On EVGA Precision, it comes back upon startup with the error, "Too many GPU"...How lame is that...
In general however, one using a software to tweak card settings (such as voltage, temp ceiling, power limit, fan speed, memory, etc) may encounter roadblocks from the software when looking to overclock a multi-GPU arrangement.
