hey Rudi,
what do you see on GPU and CPU usages?
New version 1.23.2 (SDK 1.37) *** 25.03.2014***
aoktar wrote:hey Rudi,
The graphics card cycles maximum 1200 MHz on current 928 MHz back. She should only 324 MHz clocks. Is a Titan. The CPU is virtually zero. C4D Project close. GPU clock of next 928 MHz. The desktop of C4D is empty.
The GPU goes back only to 324 MHz (Running dry) if C4D is completely closed.
Hi to all,
There is a new workflow version to pretesting
There is latest version, with some new workflow as in video:
[vimeo]http://www.vimeo.com/88780657[/vimeo]
Also last version for testing
http://render.otoy.com/customerdownload ... 1a-win.zip
Nice, that's looks like a very nice addition!
cheers
brasc
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
- shawnfrueh
Hi Aoktar, is it possible to get a 'save to picture viewer' feature for when you are rendering in the live viewer?
i'll look for it, nice ideashawnfrueh wrote:Hi Aoktar, is it possible to get a 'save to picture viewer' feature for when you are rendering in the live viewer?
hi aoktar.
can u say me, how i can get the old Turbulence 3D Space?
I have some trees and i want some color mix.
With the old Turbulence Shader i could mix some materials in the true 3D Space.
Now, the turbulence shader had uv-cordinates and wont work any more.
all shaders now have transform and projection slot. Just activate projection and select XYZ to UVW type. If you don't activate that will be uv mappedNVN wrote:hi aoktar.
also you can check projection types in this manual:
http://render.otoy.com/customerdownload ... manual.pdf
