Using this option is slow due TFD's shader sampling function. It's working much slower to calculate voxel values. Don't know why cuda errors happened. Can you post a output from logs?valters wrote:Is that ok if during working LV, in Octane Tag i switch to use 3rd party shaders and choosing Tempreture instead of Density for Abs/sct. channel, Octane goes to Render Failure (Cuda error 719) and addicionaly this failure takes down all used GPUs in LV (downgrade clocks to minimal) so i need to restart computer to "refresh" GPUs.
I found this on every TFD Sample scenes provided.
Version 3.00 - R1.1 (25.05.2016)
Here is a test build for before doing a release. I'll need some information about stability. This is first working version with material stacking. I wrote the limitations.
R17-Win: https://render.otoy.com/customerdownloa ... -test3.rar
R17-Mac: https://render.otoy.com/customerdownloa ... Macosx.zip
Changes of V3.01-test3
- Fix: ignored range parameter in animated sequences
- Fix: Not visible volume/scatter objects on first frame renders
- Experimental material stacking feature
- Fix: enabled partial-alpha parameter for old scenes.
MATERIAL STACKING LIMITATIONS
-limitations: only works with c4d materials and octane materials and will not work with mix materials in any combination
-works with flat/cube/cylindrical/spherical projection types. Doesn't account the current tag's UVW mapping coordinates. It takes it from previous material which has not alpha/opacity.
-Can work with selection assignments. But it's still limited on complex selection sets
-go with mix material setups for advanced usages
Hi Ahmet,
Thanks for the build, I'm just getting a black Live Viewer with "Updating" just counting up and nothing happens:
cheers
brasc
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
Checked but it's looking fine to me. Do you see these output in console?
- Attachments
- a1.jpg (10.15 KiB) Viewed 6362 times
Thanks Ahmet,
Yes, I get that output in the console:
I just tried going back to 3.00 r1.1 and it's now doing the same thing, it was working just before I tried this new test build.
I can also run Octane Standalone fine and it renders things.
cheers
brasc
cheers
brasc
Make a sign out from standalone+plugin and sign in. Check outputs in log window and licences page. It's working on a few guys here.brasco wrote:I just tried going back to 3.00 r1.1 and it's now doing the same thing, it was working just before I tried this new test build.
cheers
brasc
Hi Ahmet,aoktar wrote:Make a sign out from standalone+plugin and sign in. Check outputs in log window and licences page. It's working on a few guys here.brasco wrote:I just tried going back to 3.00 r1.1 and it's now doing the same thing, it was working just before I tried this new test build.
cheers
brasc
Sorry, it looks like it was an issue with one of my GPUs... If I try and start rendering with my Monitor GPU I get that issue ("Updating..." and no render), if I start with one of my other GPUs first, it renders fine and I can even add the Monitor card back in during rendering and then it works. It's probably related to that problem I posted a few weeks ago in the Bug Reports forum. I will do some more testing see if I can work out what's causing it.
cheers
brasc
Hi Ahmet,
the Test3 version is working well with me. Stacked 3 materials - one C4d with two octane.
Thanks - your imrovements are always awesome!
Ron
Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Hello Ahmet,
Just to notify you about a crash with the Daylight Tag.
In the medium tab, when you already added a medium, and then you click the "Add Fog" button, it causes a crash of c4d.
Windows 10, R17, Octane V3 1.1
Clement
Clement
