OctaneRender 2024.1 for Houdini production (2024.1.0.2)
ricky_otoy
coresign wrote:IPR is slow when moving heavy geo in object level
What are you considering as heavy? Massive network creating the geo or something like a high poly fbx import etc?
Please send us the object to do some profiling on the performance with it. Thanks!
lavrenovlad
ricky_otoy wrote:
lavrenovlad wrote:There is an annoying problem with the IPR when I switch to some frame when IPR is on, it forces Houdini to calculate something for no reason from frame 1 to the frame I am on (like running a simulation when I have literally a cache file there and nothing should be simmed), usually if I switch frames I turn off IPR and switch to the needed frame and then turn the IPR back on.
Please can you send me a test file for that specific case, we will have a look into it! Thanks man!
Will do! I am busy and don't have time to file these reports etc.
BTW I broke octane license in a funny way today, launched IPR with thousands of unique packed objects for a test, octane couldn't load that in for like 5 minutes, then my license just crashed lol and couldn't get Octane working 'cause some json file was corrupted or something. Had to clean up AppData folders for Octane and works again now :D
lavrenovlad
BTW sometimes I get this message when launching IPR, what could it be?
WARNING: All log messages before absl::InitializeLog() is called are written to STDERR
I0000 00:00:1733811406.988601 21612 config.cc:230] gRPC experiments enabled: call_status_override_on_cancellation, event_engine_client, event_engine_dns, event_engine_listener, http2_stats_fix, monitoring_experiment, pick_first_new, trace_record_callops, work_serializer_clears_time_cache
lavrenovlad
When does the new plugin version come out approx.? Waiting on it because the devs fixed the denoising crashing as I can see in the changelog, wanna test it out.
ricky_otoy
lavrenovlad wrote:When does the new plugin version come out approx.? Waiting on it because the devs fixed the denoising crashing as I can see in the changelog, wanna test it out.
2024.1.2 should be out on Monday.
coresign
Moving a subdivided test model is pretty slow.
ipr_slow.zip
(1.8 MiB) Downloaded 164 times
vurt
Hi, may I ask for a 2024.1.0 build for Houdini 20.5.445? We wish to update to the latest plugin, but we cannot use 2024.1.2 as it is not yet supported by RNDR network, and Houdini fixed some critical bug on latest production release
ricky_otoy
vurt wrote:Hi, may I ask for a 2024.1.0 build for Houdini 20.5.445? We wish to update to the latest plugin, but we cannot use 2024.1.2 as it is not yet supported by RNDR network, and Houdini fixed some critical bug on latest production release
Hey there, it has been added to the set of links.
