Cinema4D version 2023.1.2-[R7] (Obsolete stable) 27.03.2024
FxDesign wrote: I mean in requirements, it's not written "R2024.2.0", and I've seen previously on a post that Maxon changed some stuff in the core that was working before in c4d2023 for octane.
To rephrase my question, do you recommend working with this version and 2024.2.0 for production ?
I don't recommend it, they are continually making changes and it may affect our plugin structure. It means there may be problems with our update/refresh mechanism of LV for example. Anyway you can use it and I don't suppose there will be critical problems. We can fix if you encounter some weird behaviors.
SSmolak
Mask with layer group AOV doesn't work until additional empty layer is not added. Please see attachments.
mask_layer_aov.zip
(213.49 KiB) Downloaded 145 times
mask_with_layer_AOV.zip
(78.6 KiB) Downloaded 223 times
SSmolak wrote:Mask with layer group AOV doesn't work until additional empty layer is not added. Please see attachments.
mask_layer_aov.zip
Changed pin count caused this on my side, will be fixed for next build. Thanks!
Amaterasu
When creating daylight in an empty scene, octane will crash
2024-01-10 14-13-30.mp4
(667.8 KiB) Downloaded 1949 times
Amaterasu wrote:When creating daylight in an empty scene, octane will crash
Fixed! Please use replaced links.
Delizade
The RefShader LV update problem seems to be gone.
THANK YOU SO MUCH FOR THIS!
hazenkind
2024.2.0 and Octane 2023.1.2. strange Bloom behavior. Its "Overbloom". Any Workaround? Not the same as in LV.
Edit: switched back to an older Version, same thing. But i noticed: If i render in HD everytihng is ok, if output is 4k i get this overbloom. Strange.
azumbrunnen
Does this include RT HW acceleration for m3? If not, which version do I need or any estimate when this comes out?
SSmolak
hazenkind wrote:2024.2.0 and Octane 2023.1.2. strange Bloom behavior. Its "Overbloom". Any Workaround? Not the same as in LV.Strange.
azumbrunnen wrote:Does this include RT HW acceleration for m3? If not, which version do I need or any estimate when this comes out?
You need 2024.1-Alpha2, but please note that it is a test version not ready for production:
https://render.otoy.com/plugindownloads ... R2_OSX.zip
ciao,
Beppe
