neonZorglub wrote:Hi ofirgardy,ofirgardy wrote:I'm encountering a Stack Overflow when attempting to render a scene with "AOV Output".
I've recently updated to Max 2023.3
When attempting to open the Render Settings of a saved file (that used to render properly) it crashes.
I've also started a new scene, and merged the content of the "defected" scene. resetting it all back will yield that Stack overflow when attempting to add the AOV Output on the render elements.
any idea?
Thank you for reporting this issue.
There seems to be a bug when some AOV output are added in the Render elements.
You might also be able to recover your scene this way:
-open the scene
-open Octane viewport (using the context menu in a 3dsmax viewport)
-click the last button (multi-pass selection) and choose 'Export passes selection to Render Elements'
This should cleanup the render elements (this doesn't include the AOV elements)
It seems you can add 1 AOV render element for now, but it might crash again if you add a second one..
Sorry about that.
This will be fixed in the next release, in the coming days.
Thanks. Good idea since indeed I was struggling to get the scene back to a workable state and Merging and re-doing the settings all over was tedious.
