OctaneRender® 2022.1 RC 1 (updated 2022/11/3)
coilbook
haze wrote:I've added the Mac build. Here it is for convenience.
Octane X Prime 2022.1 RC 1 for macOS
Hi haze,
Can we please get an option how foggy is foreground and how fogy is background. I asked many times and I just get ignored. This will help a lot. Your company should hire a professional 3d artist who can tell you what your software is missing. And it needs a lot of things.
3dworks
please when will we get a version with network rendering? waiting a long time for it...
Padi
abstrax wrote: So just to be sure I understand: You open the application, the splash is shown, the splash disappears, the application window is opened and fully populated and then it crashes before you can do anything?
The application window is not populating. It just creates the window frame filled black and crashes immediately. The license gets locked and I need to open an older version to have it unlocked (or use unlocks on the website).
I will DM mojave now so you can look into the machine more closely.
haze
Hi haze,
This is coming for 2023. Should be in the first beta release of it. By the way, my son loves watching your show.
haze
Thanks for your message. Could you PM me any details of your network rendering setup please? At the moment, Mixing Mac and CUDA nodes will not work, but this is going to be fixed in 2023.
Obizzz
haze wrote:Hi all
  • Made coherent ratio less aggressive.
Happy rendering
Your OTOY team
Does this change the formula used in this calculator or should we still stick to those values if we want to be sure the coherent ratio is fully calculated to avoid flickering in animations? https://codepen.io/blastframe/full/mdmNmpa
haze
Obizzz wrote:
haze wrote:Hi all
Happy rendering
Your OTOY team
To do a perfect conversion change this line
  let cr = (parseInt(max_samples)*0.35)/1024;
to this
  let cr = Math.pow((parseInt(max_samples)*0.35)/1024, 1.0/3.0);
For speed, try also increasing your parallel samples (unless you have already)
john_otoy
OctaneRender 2022.1 RC 2 has been released: viewtopic.php?f=33&t=80756
