Updated!
viewtopic.php?f=85&t=79824&p=412343#p412343
Cinema4D version 2022.1-XB1-(R3) (Experimental) 02.06.2022
Thank you, color VDBs work great!aoktar wrote:Updated!
Thin film in standard surface material still doesn't work
Have you checked in Standalone? It's not working in there too.Meet wrote:Thank you, color VDBs work great!aoktar wrote:Updated!
It's working if you connect a float texture. Assumed that's not working because used rgb color.Meet wrote:Yes, I had checked and asked, it works in standaloneaoktar wrote: Have you checked in Standalone? It's not working in there too.
Metalness is 1
Undo doesn't work if node is still selected after changing parameter while using embedded GUI
- jiabangshou104
"Photon Tracing "often gives memory RAM errors when noise reduction is enabled.
Octane Render AOV group cannot be saved.
"Photon tracing"在开启降噪时经常出现内存RAM报错。
使用Octane Render AOV group时无法保存。
Changing Layered Material type to different one like Diffuse doesn't work. Only way is to create new material from scratch.
Not sure what are you showing and how you can see this menu command. It's not appearing on sub materials. And deleting/creating is not only way to change the type. See pic.SSmolak wrote:Changing Layered Material type to different one like Diffuse doesn't work. Only way is to create new material from scratch.
I mean Octane Composite. I thought that this menu is to convert it to something else ( not layered one ). I have old material with which is layered that now can be done using Octane UIniversal but I see that there is no way to simple convert or change it to Universal one.aoktar wrote:Not sure what are you showing and how you can see this menu command. It's not appearing on sub materials. And deleting/creating is not only way to change the type. See pic.SSmolak wrote:Changing Layered Material type to different one like Diffuse doesn't work. Only way is to create new material from scratch.
