Thank you for this awesome release!
Do you plan on having a way to tell a light / environment NOT to generate caustics?
For example I have a great scene that has wonderful caustics with an area light but as soon as I turn the environment on, it gets really messy and increases the render time.
Cinema4D version 2022.1-XB0-(R1) (Experimental) 29.12.2021
Thank you Aoktar!
Really loving the new kernel.
I'm having crashes anytime I try to save a rendering through the Render OAV group window. It renders and crushes right before saving.
With any scene, even just a simple sphere, no lighting no environment and regardless of file format.
Anybody having the same issue?
Thanks!
Thanks!
- shinybinary
I have the same issue, trying to save out aov passes crashes c4d as soon as the render ends.mrbrown wrote:Thank you Aoktar!
Thanks!
"Crushing" is meaning "crashing" I think. Just save and send the your cr(u)ashing scene to let me reproduce it.mrbrown wrote:Thank you Aoktar!
Thanks!
Hey Aoktar, thank for the reply.aoktar wrote:"Crushing" is meaning "crashing" I think. Just save and send the your cr(u)ashing scene to let me reproduce it.mrbrown wrote:Thank you Aoktar!
Thanks!
And sorry for the misspell..
Here is a scene that recreates the same problem
Let me know.Thank you!
- Attachments
- crUsh.zip
- (112.27 KiB) Downloaded 281 times
It is not crashing when I try to render. What should I do?mrbrown wrote: Hey Aoktar, thank for the reply.
Not sure what is causing the problem
Could you take a look at the bugreport and see if there is any additional info on what is causing the problem?
Thank you!
Thank you!
- Attachments
- _BugReport.txt
- (735.83 KiB) Downloaded 274 times
- luminouspowerhouse
1. OctaneRender-for-C4D-2022.1-XB0_R1 still shows 2021.1.1 in C4D IPR
expected: installed version
2. Disabling "Camera visibility" for HDRI texture still shows it as Background image in IPR and rendering
expected: HDRI texture to disappear in render
3. Changing ACES LUT, resets exposure
expected: change of ACES lut not to reset exposure
See video attached
See video attached
- Attachments
- Octane 2022 - Inconsistencies - 2022-01-22 16-45-58.mp4
- (13.51 MiB) Downloaded 6425 times
Which issue that's bombing something?bottom wrote:I'm having the same issues with AOV's.
As soon as it comes to saving the image Octane bombs C4D.
