OctaneRender 2020.1 for Houdini Production build 2020.1.5.3
ptunstall
Hey Juanjo are you aware of any memory issues with 2020.1.5.2? A scene that fails to render with both OOC on and off seems to render just fine in 2020.1.5 standalone. The same houdini session that fails to render, outputs a working orbx file that immediately works without closing houdini or any other application.
We are in centos 7.7 with GPU driver 450.66
 *** OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
 *** OCTANE API MSG:   -> failed to copy memory to device.
 *** OCTANE API MSG: device 0: failed to upload data texture 17 '0:__data15__'
 *** OCTANE API MSG:   -> failed to deallocate device memory
 *** OCTANE API MSG:   -> could not get memory info
 *** OCTANE API MSG:   -> failed to destroy CUDA event
 *** OCTANE API MSG:   -> failed to deallocate pinned memory
 *** OCTANE API MSG:   -> failed to deallocate device array
 *** OCTANE API MSG:   -> failed to destroy texture objects
 *** OCTANE API MSG: Failed to free page-locked memory
 *** OCTANE API MSG:   -> failed to unload module
 *** OCTANE API MSG:   -> failed to bind device to current thread
 *** OCTANE API MSG: device 0: failed to initialize context
 *** OCTANE API MSG: device 0: failed to initialize render thread 0x7fdda5092600
 *** OCTANE API MSG: device 0: failed to initialize render thread 0x7fdda35f2000
 *** OCTANE API MSG: device 0: failed to initialize render thread 0x7fdda35f5e80
 *** OCTANE API MSG: device 0: failed to initialize render thread 0x7fdda508f400
 *** OCTANE API MSG: device 0: failed to initialize render thread 0x7fdda2391b00
 *** OCTANE API MSG: device 0: failed to initialize render thread 0x7fdda2394f80
 *** OCTANE API MSG: ORC user subscription status could not be retrieved: The server returned a client-side error with HTTP code: 401
 *** OCTANE API MSG: ORC subscription status cannot be found
 *** OCTANE API MSG: device 0: failed to initialize render thread 0x7fdd29e86d00
Should we update to your 1.5.3?
ptunstall
We're going to try 2020.1.5.3 and see what happens. That fix sounds confusing but also potentially our issue.
juanjgon
ptunstall wrote:Hey Juanjo are you aware of any memory issues with 2020.1.5.2? A scene that fails to render with both OOC on and off seems to render just fine in 2020.1.5 standalone. The same houdini session that fails to render, outputs a working orbx file that immediately works without closing houdini or any other application.
This is really weird. The Octane core in Standalone 2020.1.5 and any of the 2020.1.5.x Houdini plugins is the same. Perhaps the problem is that somehow Houdini is using resources in the GPU (the final available VRAM perhaps) that is breaking Octane. Also be aware that perhaps some settings are not the same between the plugin and Standalone, like the out of core configuration, or the device's configuration (tonemapping, RTX enable, etc).
trogers
Hi Juanjo,
One thing I've been noticing when running the Octane IPR in Houdini is that if I accidentally ask the IPR to reload before Houdini is finished calculating my node tree it will completely freeze Houdini and require me to end the task. I just had this happen while QuadRemesher was running and I didn't notice that it was still processing when I clicked Refresh.
Thanks!
Win 11 / AMD 3970x / Nvidia 4090 + 2080 Ti / 128GB
juanjgon
trogers wrote:Hi Juanjo,
Thanks!
Hmm, but this is something really weird. How is Houdini live while it is still cooking a node tree? I'll try to reproduce this problem here.
andrevalle
When the plugin for Houdini 18.5.462 production build will be available?
André Valle
juanjgon
andrevalle wrote:Hi,
André Valle
The roadmap for the next week is to release both a new Octane 2020.1 and 2020.2 plugin builds for the new Houdini production build. It is a matter of few days.
andrevalle
Great!
Thanks Juanjgon.
All the best,
André Valle
juanjgon
I've updated this post including a proper new Octane 2020.1.5.3 plugin build for Houdini 18.5.462, the latest Houdini production build available.
