Proxies workflow
Hesekiel2517 wrote:Hi Dingbat,
i think the solution to your problem is to create a lowpoly Version of your highres Mesh (or a simple cube with the right dimensions) to use them in the Meshlayer you use as a proxy. So you can see your lowres Meshes in the viewport, but Octane will pick up your prepared Orbx for rendering.
Yes, you can use a Modo cube Mesh Item and attach the ORBX proxy to it, so you can see the positioning in the Modo OpenGL window.
Dingbat
i do that sometimes, but it's just wasting time on really tedious stuff if you have a large library of trees and plants
and also if i need to switch to the MODO render engine for any reason, the render will be completely different as MODO will only render the low poly versions.
attaching the ORBX to a deferred mesh, in the same way you can attach it to a regular mesh would be a great compromise, and shouldn't be too difficult to add?
I am really sorry, but this is not an easy feature to add, and there is a long backlog if other features that I need to implement, so it's not something I can do in the short to medium term.
Dingbat
face_off wrote:I am really sorry, but this is not an easy feature to add, and there is a long backlog if other features that I need to implement, so it's not something I can do in the short to medium term
fair enough. thanks for considering
Return to “Foundry Modo”
