OctaneRender® for 3ds max® v2019.1.1 - 8.09
paride4331
mbetke wrote:431.86 the creative drivers or what is it called. Not the gamers one.
Hi mbetke,
have you any slave daemon running on master or are you using compressed textures?
Regards
Paride
paride4331
coilbook wrote:HI All,
Can anyone try to open the scene and go to frame 3374 and see of you have motion blur or not. We use max 2020.2
Hi, Paride,
I sent the same scene through wetransfer. It is attached here too. Wetransfer was giving us problems.
Thank you
Hello coilbook,
it seems an MB issue using standard camera.
a work aound is creating an Octanecamera "dummy" tu activate MB then setting it in Octane RenderSetup.
Regards
Paride
motion blur bug default color5.zip
(63.87 MiB) Downloaded 395 times
Elvissuperstar007
the render worked at night, then it didn’t work anymore
octane render 3ds max 2018.1 2019.1 1019 .1.1
NVIDIA 1080 GTX 8gb 64 GB DDR 3 CPU memory 6Gb
nvidia 436.48
users with a regular V4 license 2018-2019
https://cloud.mail.ru/public/5iB1/3MRKQifDZ
Last edited by Elvissuperstar007 on Fri Oct 04, 2019 9:49 am, edited 1 time in total.
coilbook
Hi, Paride,
Thank you
Hello coilbook,
Regards
Paride
HI Paride,
thanks.
Will you report this to developers?
Did you have a chance to look at emission ramp not working in real time and then crash viewtopic.php?f=81&t=72795 and particles motion blur viewtopic.php?f=81&t=72801?
Thank you
mbetke
Hi mbetke,
Regards
Paride
No. Just my workstation. I didn't touch any texture settings.
PURE3D Visualisierungen
paride4331
Hi, Paride,
Thank you
Hello coilbook,
Regards
Paride
HI Paride,
thanks.
Thank you
Hi coilbook,
I reported viewtopic.php?f=81&t=72801#p370027 to developers yesterday,
I will investigate viewtopic.php?f=81&t=72795 today.
Regards
Paride
coilbook
what do i need to do to make my primitives render as volumes?
Thank you
What material choose for vectron
coilbook
Hi Paride,
there is a bug where octane just randomly doesnt render certain objects. It can be mesh, volumes, particles etc. Octane viewport or max has to be restarted
this version closes max 2020.2 Not all the time After we simulated multiple phoenix grids one of them was not rendering in octane viewport. Then we did regular rendering and max just closes. There is some kind of bug with not rendering some elements especially they are related to phoenix
And what does this mean
Can't connect node 'mtl-Material #2097646154' (NT_MAT_GLOSSY, 0000025557E46B00) to dynamic pin 'Layer 2' (type PT_MATERIAL_LAYER) of node 'Layered material' (NT_MAT_LAYER, 0000025557E417C0)
Can't connect node 'mtl-Material #2097646154' (NT_MAT_GLOSSY, 000002555B089840) to dynamic pin 'Layer 2' (type PT_MATERIAL_LAYER) of node 'Layered material' (NT_MAT_LAYER, 000002555B085160)
Can't connect node 'mtl-Material #2097646154' (NT_MAT_GLOSSY, 00000255B2CE8940) to dynamic pin 'Layer 2' (type PT_MATERIAL_LAYER) of node 'Layered material' (NT_MAT_LAYER, 00000255B2CE20A0)
cannot import a regular grid from an empty voxel buffer.
Elvissuperstar007
export ORBX does not work correctly,
I am losing materials in the standalone version
everything is fine the first frame there is material, on the second frame it is white
paride4331
Elvissuperstar007 wrote:export ORBX does not work correctly,
Hi Elvis,
all seems to be ok, any info about your issue?
Regards
Paride
test.mp4
(3.99 MiB) Downloaded 3753 times
