OctaneRender 4.05 for LightWave Production build 4.05.0.0 [OBSOLETE]
juanjgon
No problem! I'm glad that the problem has been resolved.
BraceMedia
Will this plugin v4 be updated to install with LW2020, when it is released?
juanjgon
Hmm, probably not. We don't have any planned updates related to the current Octane 4.0x plugins. Any new LightWave version will be supported in the Octane 2019.1 and Octane 2020.1 plugins.
BraceMedia
Will we be able to 'try' to install the plugin as normal, in 2020? Or will that not work at all?
juanjgon
Sorry, I'm fairly sure that the LW 2019 plugin is not going to work in other newer LW versions but let's see once available.
BorderLine
Hi JuanJo,
How works Out of core geometry please ?
juanjgon
BorderLine wrote:Hi JuanJo,
It is enabled automatically when you enable the out of core option in the plugin options panel. The same option enables the out of core for the textures and for the geometry.
BorderLine
Thanks !
BorderLine
JuanJo,
If I understand correctly, the memory limit (texture and geometry) becomes the limit that I indicate to him in "out of core", in addition to my card memory ?
So I'm no longer limited to my GPU memory.
Crazy !
BorderLine
Hi JuanJo,
IS it Ok for LW 2020 ?
