Cinema 4D version 4.04-R2 (Obsolete stable) 06.05.2019
cmittenaere
With the render network.
I don't understand why, but it's detected on the main, my first laptop see the render server, but don't use it...
Sometimes, when i'm delete rendering network and restart it ti's work..
divasoft
Hi Aoktar. Why Sheen layer not react on changes in noise node? is it bug? Standalone works fine.
i record video https://drive.google.com/open?id=1glGQo ... lN7ZFD4cvm
divasoft wrote:Hi Aoktar. Why Sheen layer not react on changes in noise node? is it bug? Standalone works fine.
Seems like I missed to enable bump/normal for sheen and coating for V4. It's available on 2018 builds. I'll make a hotfix
divasoft
Thanks for the answer. But version 2018 requires a subscription purchase. Me and my colleagues, will not buy a subscription until Otoy changes the licensing policy and octane updates become permanent.
Divasoft,
I talk about a fix V4, this is the 4.04 topic. Thanks
divasoft
aoktar wrote:Divasoft,
By the way, coating normal map also does not respond to changes.
https://drive.google.com/open?id=16Xn4E ... sT_Xzd8Txm
igoriisakov
In 4th version I see one thing that my work horrible: when I use 1024 and higher resolution of editor display, in material settings, all actions in 3d view have freezing. In v3 there are no freezes in all resolutions. Please fix it, because work in small resolution of display materials is not right way. Cinema 4d r19 with latest update. Waiting this from update to update but nothing chancing...
igoriisakov wrote:In 4th version I see one thing that my work horrible: when I use 1024 and higher resolution of editor display, in material settings, all actions in 3d view have freezing. In v3 there are no freezes in all resolutions. Please fix it, because work in small resolution of display materials is not right way. Cinema 4d r19 with latest update. Waiting this from update to update but nothing chancing...
What's driver? Try to upgrade it.
There's a HOTFIX for this:
Version 4.04-R2.
divasoft
aoktar wrote: There's a HOTFIX for this:
Version 4.04-R2.
Oh, thanks)
