OctaneRender 2018.1 for LightWave Beta build 2018.1.0.6
artecnl
juanjgon wrote:
artecnl wrote:im new to octane and maybe is a dumb question, i can install both , the beta and the last version together in LW2019?
Not at the same time in the same LightWave, but you could install two LightWaves, each one configured to use its own config files, and install a different plugin version in each one.
Many thanks Juanjgon¡
BorisGoreta
Octane Vertex Attribute works fine locally but crashes the nodes.
juanjgon
BorisGoreta wrote:Octane Vertex Attribute works fine locally but crashes the nodes.
Do you know if an .orbx created from your scene crashes the Standalone? Could be great to have a repro scene. If you want to send me the LW scene, I can try to export it myself here.
ceturtu
Hi Juanjo, it doesnt shows the textures on the models. all white
juanjgon
ceturtu wrote:Hi Juanjo, it doesnt shows the textures on the models. all white
Do you say that the texture image node doesn't work at all? I don't have other reports about a problem like that!
Return to “Lightwave 3D”
