OctaneRender™ 2018.1 XB2
abstrax
Renart wrote:Nice release!
Do you have a sample scene regarding vertex color attribute?
I've made a test model (fbx) with Quill and imported it in Maya where I get the colors using the "_VertexColor" attribute.
But in Octane I can't manage to make it work :/
Thanks!
Edit: It's also working with blender if I read the Attribute "Col" for some reason..
But in Octane it still doesn't work if I use this name
Import and export of vertex attributes via files isn't supported yet in this version. The next version will support import and export of vertex attributes via Alembic. FBX will follow next year.
abstrax
Notiusweb wrote:Two findings with this 2018.XB2 build
1 - if you alter scene while denoiser is active, it will show serious spikes in Delayed Procedure Calls (for those of us with USB 3.0 PCIE connected GPUs). If you have Denoiser off, spikes are not nearly as significant.
So, you run the risk of a crash if you tweak too much while denoiser is on, but if you turn off and tweak, no issue. So, what I do is only use denoiser at the end when I'm rendering, and no longer fiddling with anything in the scene.
We are planning to get rid of the page locking of the film buffer channels during denoising. This might help with your issue, but I' not sure. This work started a couple of months ago, but had to take a backseat to allow us focussing on stabilizing version 4 and getting 2018 out.
2 - I found that if texture path and name exceeds a certain # of characters, when you try to load that texture into a material, it will crash Octane. If I then rename the material to a 1 or 2 character file name, it loads fine.
(I didn't yet identify what that character count is yet, but I am using Win 10.)
But, then also, if I bring the original full-named texture file to a higher level folder, it then also loads fine.
So it seems Octane doesn't like materials having texture names & paths that extend out too far with too many characters.
Are you talking about the Standalone or about a plugin? There shouldn't be a limit in name length in the Standalone, but if you experience issues, could you maybe send me the name of the file you tried to load?
abstrax
coilbook wrote:14000 samples later in AO. Just noise. 20 x 1080ti - 5 min to render. Why do cpus calculate cleanly and gpus just cannot. I know CPUs are slower but they do the job.
Maybe GPUs just cannot handle a big varieties of colors, lights and objects at the same time. GPUs are very slow at rendering stuff like grass but fast at one uniformed color like sky.
And denoiser creates blotchy patches out of that blue noisy interior ceiling.
Can we get a bucket mode to do clean final renderings?
In the image you posted it looks as if the light sampling is struggling. If you send me the scene, we can have a look and try to understand what is going on and how things can be improved. Thank you.
PolderAnimation
abstrax wrote:
PolderAnimation wrote:Could the padding size in the bake camera be unlocked to 100 or 200 of something like that? Would help allot thanks.
In principle we could do it, but it would be quite slow to calculate. Why would you need such a large padding?
Long story but I am working on a bit complicated stylized look. Unfortunately I just came across other issue that are harder to solve so I think I have to find another approach. So the large padding is not necessary. Thanks of the reply.
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
PolderAnimation
I do have another request :). I already posted this in the RC7 thread of octane 4 (so sorry for the double post).
I would love to have control in the toon shader over the shadow color. So that per shader you can select a shadow color instead of a shadow color for the whole scene.
And an texture input for the toon ramp would also be great. Now we can only use float (vector) values.
Notiusweb
Could we get an Opacity or mask channel inside settings for Displacement texture, as we can't use multiply texture, add texture, etc, on displacement, just image. Would like to mask out sections of the displacement image, but doesn't seem you could do that natively inside Octane standalone.
THX!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
calus
Notiusweb wrote:Could we get an Opacity or mask channel inside settings for Displacement texture, as we can't use multiply texture, add texture, etc, on displacement, just image. Would like to mask out sections of the displacement image, but doesn't seem you could do that natively inside Octane standalone.
Already possible :
plug any usual texture graph to a bakedImageTexturenode plugged in displacement.
(the texture graph is baked on the fly to a temporary image buffer feeding displacement, but only support uv projection)
Pascal ANDRE
Notiusweb
Already possible :
Whoa!
Nice one, yes!
In Displacement you can add a BakedImageTexture, and then in the texture select Multiply Texture, Add Texture, etc...
This is a great tip, thank you Calus!
Plugs: Enterprise
PolderAnimation
Thanks!
Will it be possible to bake lighting data to vertex attributes?
coilbook
please look into 3ds max crashing when octane lights are copied with octane viewport opened
