tried it. no difference:aoktar wrote:... Try with this option. ...
not sure, what that means. something i can do to help?aoktar wrote:...It will try to find and match the particle motion by their ID's.
well, that's a bummer. thanks for looking into it though.aoktar wrote:Ok, after checking that again you're right! Nothing solved. But hard to know where's problem. Somethings causing problems on this kind of setup of xp emitter. Probably it's on Exporter stage of plugin. There's not much thing to do in a short-time.
sorry to say, but at the beginning of this thread i once mentioned that i also tried the abc-files on octane-scatter-object way.aoktar wrote:... Somethings causing problems on this kind of setup of xp emitter. ...
: in field 'start'
[string ""]:921: in field 'batchRender'
[string ""]:668: in function <[string ""]:659>
[C]: in method 'showWindow'
[string ""]:1096: in main chunk
CUDA error 999 on device 1: unknown error
-> failed to unregister pinned memory
-> could not get memory info
-> could not get memory info"
