OctaneRender™ 3.0 for LightWave™ - Test build 3.08.0.7 RC1
gordonrobb
Would that cause this strange behaviour thiuggh? The files are still in he original location also.
I’ll try again when I get home though.
juanjgon wrote:
gordonrobb wrote:Thanks for this.
I'm having some problems though. To be sure I wasn't doing anything stupid, I downlaoded the 2018.0.2 update so that I was starting on a new install.
I downloaded the Plugin.
I made sure I extracted the 2018 version
I coped the files you need to copy and put them in the bin folder (as normal) of the 2018.0.2 install
I added the plug in
I installed the menu tree.
Any ideas?
Hmm, you don't need to copy any file to the LightWave bin folder, this was a really old install procedure. All the needed files are now located in the same place used by the plugin .p file, so you only need:
- Extract the plugin folders from the .zip file to any HD location.
- Add to the Layout the plugin .p file (the one for your LightWave version)
- Add the menu branch
You don't need to make anything else and you don't need to copy anything to the LightWave folders.
Hope this helps,
BorisGoreta
Good to know ! I take it will be possible at some point, am I right ?
juanjgon wrote:
BorisGoreta wrote:It appears that image sequence with F10 does not get saved. Switching to LW renderer the sequence gets saved.
In LightWave 2018 all the images must be exported from the passes node, including the beauty pass. The new LightWave 2018 buffers system is not supported yet.
gordonrobb
Started from scratch again and it all worked.
juanjgon
BorisGoreta wrote:Good to know ! I take it will be possible at some point, am I right ?
Yes, probably, but in any case, even in LW 2015, you needed to use the passes node to export any AOV. The LightWave image saving functions are used only for the beauty pass ... now in 2018 all the image files/paths must be configured in the passes node, even the beauty pass.
3dreamstudios
Juanjo,
Did the IPR selected feature get added to this build? I'm not seeing it on the menu, but maybe it's a command that I have to map to something? I thought I had remembered you saying it was ready for next build...I might be forgetting. Thanks.
BorisGoreta
Would it be possible, at some point, to shift click on a fiberFX surface in the IPR to open that surface in the node editor like we can do with regular surfaces ?
vipvip
thanks for your answer.
It is very strange : if the pc is online, the plugin activation is OK :once disconnected with the same LW session, it still works but if i close LW 2018.02 & reopen a new session , when enabling octane, it asks to be connected to activate the plugin !...
The offline option is ghosted, so no access to it...
juanjgon
3dreamstudios wrote:Juanjo,
Yes, they are two additional commands that you can map to a key or add to a menu branch.
juanjgon
vipvip wrote:thanks for your answer.
I'm not sure, but I think that until the offline licensing is fixed, you must be always connect to internet to enable the plugin.
3dreamstudios
Oh this would be nice, I've hated the 5-15 seconds I have to wait for licensing to activate, such a pain. I have 100 megabit connection...so it's not me :)
Return to “Lightwave 3D”
