OctaneRender™ 3.0 for LightWave™ - Test build 3.07.0.0
- BorisGoreta
- Contact:
But as I understood they will fix that, no ?
- BorisGoreta
- Contact:
Octane does not support this file type anymore, it is 32 but format which used to work before.
- Attachments
- sea_tex_0000.rar
- (5.06 MiB) Downloaded 316 times
- BorisGoreta
- Contact:
But the exact same image was working some versions before because I was doing other projects with it.
It was a bug in the 3rd party library we are using. Roeland fixed it with the stable 3.07.BorisGoreta wrote:But the exact same image was working some versions before because I was doing other projects with it.
- Jackytalpalar
Hey Juanjo, I'm having trouble with the Network options, now Lightwave doesn't remember if a network daemon is enabled, from session to session...
- Jackytalpalar
I don't think so, I never use the standalone. In previous versions LW always remembered the network settings and it was easy to use the render-q, now I need to check the box every single time I open LW. I'ts not that terrible as it is, but was better beforejuanjgon wrote:Hi,
The network options are a global setting on the system. I mean, if you configure them from Standalone the plugin settings will be overridden. Can this be your problem?
I think that this problem has been fixed in the final 3.07 Octane core: "Fixed loading of the net render daemon selection from the preferences.", so it should be also fixed in the next build of the LightWave plugin that I want to release later this week.Jackytalpalar wrote:Hey Juanjo, I'm having trouble with the Network options, now Lightwave doesn't remember if a network daemon is enabled, from session to session...
