Clients crash / network rendering
no the crash is not necessary to generate the log, if you enable all the log checkboxes, it will register as much as possible.
Please, share the c4doctanelog.txt after rendering a couple of frames.
ciao Beppe
young.r85
Beppe,
I've made a change that seems to "fix" the issue. If I save using the built in Cinema4D field, instead of using Octane's Render Passes option, everything is rendering just fine.
I use to save everything through Octane's Render Passes tab, turning on the Save Beauty checkbox. But now that I'm saving through C4D's native field, I'm not experiencing the crash.
I'll retry Rendering the old way once these renders complete. They are due tomorrow so I don't have time right not to help diagnose the issue. Once I test again, I'll upload the log files you requested.
Thanks for your time and attention. Stay tuned!
R
