OctaneRender™ Standalone 3.07 TEST 3
coilbook
i know it is not for this plugin but PELASE otoy address phoenix overlapping grids problem viewtopic.php?f=80&t=62505&p=320258#p320258
I told paride just in case i post here. vray does not have this issue with visible edges of overlapping grids It renders grids like they have refraction in them even though grid borders are just empty cells
grimm
abstrax wrote:
enricocerica wrote:I probably missed something but I cannot use the gizmo to move/rotate/scale an object.
I add a placement node for a mesh, select it and activate any of the transform icons but don't get any transform icon whatever is the gizmo mode (local or world).
Any tips ?
Ok, it seems you have to enable the object picker tool (see viewtopic.php?p=320255#p320255). We will fix the bug in the next release. Sorry about that.
I tried to activate the object picker tool, but it didn't make any difference for me. Still didn't show the gizmo on Linux.
noldo
For the gizmo, try to insert render target node, and link the placement (or scatter) node to the render target.
grimm
Thanks, but I tried that too, unfortunately no difference.
andrey.krivulya
Any news about Ornatrix hair and requests in this topic?
viewtopic.php?f=9&t=61546&p=314835#p314835
Windows 11 Pro / Intel Core Ultra 9 285HX / 96GB DDR5 / RTX 5090 Laptop 24GB / 4TB SSD / MSI Titan 18 HX AI
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
enricocerica
grimm wrote:Thanks, but I tried that too, unfortunately no difference.
Yep, same for me, I added a render target and activated the object picker, but no way. Let's wait the fix ...
http://www.myline.be
abstrax
Hmm, I have been trying to reproduce the reported issues, but here it works fine. So I don't know what's going on yet. Which camera do you use?
Could you try the attached scene and let me know if the object handles work for you in this scene? If they do, it must be a scene specific problem in which case it would be great, if you could send me the scene (or a stripped down version of it). Thank you.
objects.orbx
(150.66 KiB) Downloaded 374 times
enricocerica
I confirm, it works fine with your scene, very strange :roll:
Edit : I think I have identified the problem, at least for me, the problem doesn't seem to rely to Octane but to the object. In my case the origin of the object is far from the object itself, after made some rotation with the camera the gizmo appeared but was not visible at first. Could other people having the same issue check if the origin of the object is on the object or so far that it can't be visible.
grimm
Thanks Enrico, I can confirm as well. Although I was not able to find the gizmo on my objects, they just must be very far away from the object. It appears that when I use objects from 3D-Coat, the origin is not setup correctly, or maybe not at all? If I reset the origin in Blender they work fine. :)
dust-test.orbx
(11.74 MiB) Downloaded 360 times
fish
Thank you for the gizmo tool.
