OctaneRender® 1.0 beta2.46 [OBSOLETE]
Jaberwocky
abstrax wrote:
Jaberwocky wrote:Hi guys
Got a bit of a problem.
I did something silly and set up a default setup in this version after renaming the all the default nodes.
2.46 / 2.45 will not now open up.They just crash.I have uninstalled/Reinstalled it - no go
Then unistalled and cleared out octane traces in the registry using Ccleaner and also searching and deleting manually all traces of octane.The rebooted and reinstalled Octane.Still no go.It will not boot.
Anyone know where the save as default config file is located so that i can delete it so that Octane returns to it;s default state.
Cheers for any help.
On Windows the default file is <user folder>\AppData\Roaming\Refractive Software\defaults.ocs
Marcus
Thanks Marcus i'll delete it and reinstall Octane.
abstrax
What have you actually done? I just renamed all nodes in the preview configuration node to test and saved it as default and don't have any problems.
Marcus
Jaberwocky
Marcus
I altered this node.Please see attached.
Maybe it needs locking off so that someone else doesn't do the same as me.
matej
Well, I confirm what Jaberwocky experienced. I just renamed "Preview configuration" to "Config", saved as default and the next time Octane crashes (illegal instruction)
cgmo.net
ALTO
Thank you for this update.
For people who is asking for the zip version, just use 7zip and extract the exe, Octane works without installing!
hadouken
New Manual! I'll be reading this and sipping on my coffee while rendering at work. Thanks for the quick fixes from .45 team.
Intel Core i5-2500
6GB DDR3
GTX470
Windows7 Home Premium 64-bit
http://zaixxiaz.com/
adrencg
Thanks for the material tooltip fix. Depending on your workflow, you just can't know what a big deal it is to see the material names on the nodes. I would prefer to have them visible at all times as an option. Too much to ask?
Ryzen 5950x
128GB Ram
RTX 3070 x 3
abstrax
adrencg wrote:Thanks for the material tooltip fix. Depending on your workflow, you just can't know what a big deal it is to see the material names on the nodes. I would prefer to have them visible at all times as an option. Too much to ask?
Sorry, I don't understand this. Where would you display which names?
Marcus
abstrax
ALTO wrote:Thank you for this update.
Cool, didn't know this. Thanks for the tip. It's quite handy.
Marcus
adrencg
Marcus
I don't know....maybe the node would change size to accommodate.
Ryzen 5950x
128GB Ram
RTX 3070 x 3
