Maya plugin 3.06,4_11.7 use pick focus region
BK
p.jsi wrote:Hi,
Yeah with number 1 there is no problems works fine. With number .2 its seems to be shifting even if the 'use pick focus region' is unchecked/disabled.
The reason like before other cameras(which has the 'use pick focus region' checked/enabled) seems to be affecting. But solution is the same, leaving unchecked in all cameras. Just letting you know anyway.
Hey P.jsi,
Thank you !!! Would you mind sending me a video please, while we taking a look here :)
Kind Regards
bk3d
p.jsi
Hi Bk,
Please follow exactly the same steps as the previous video but this time keep the auto focus unchecked. Try different area size as you do render region and the focal depth changes accordingly.
Hope this helps.
BK
p.jsi wrote:Hi Bk,
Hope this helps.
Thank you P.jsi..
Kind Regards
bk3d
Return to “Autodesk Maya”
