Missing :
Scene Outliner and all Node Ispector icons
Uninstalled because it cause a infinite time loading when opening file [it always starts to BUILD OCTANE GEOMETRY on load]
Thank you for testing, we will be bringing out a new version shortly to fix the first and third problems you mention, the second issue is one that I need to look into:ArchMP wrote:
Missing :
haze wrote:Thank you all for your enthusiastic reception of the plugin and issue reports. Regardless of internal testing we anticipated some problems, and CC is working on these right now.
Please keep in mind that there is a good deal of changes made in Octane core to make the major changes you see in the plugin happen. Octane is on a different development cycle, but we will of course try to make these coincide with the plugin test releases.
smicha -- regarding the shortcut buttons on the node stack - I made the change but this caused some issues in Modo plugin, so I had to revert it. I'll be working on a permanent solution to this soon, but am currently stuck on another task. Please bear with me.
