I really can't reproduce your problem: Could you please send me your scene, so I can investigate? Thank you.Elvissuperstar007 wrote:This bug exists in 2.26.1
This panel geometry, there is no displacement
OctaneRender™ Standalone 3.04.5
- Elvissuperstar007
- Contact:
scene
- paride4331
Hi Elvissuperstar007,
I checked the issue you've reported.
Thanks for your help.
Regards
Paride
Regards
Paride
Ok, after sorting out all the confusing information about this issue, it seems that there is an integer overflow when the 3ds max plugin copies the render result into an internal bitmap. Antonio will be looking into it. The rendering itself is fine as well as rendering in the Standalone.Elvissuperstar007 wrote:https://cloud.mail.ru/public/x527/ccMNDfGDg
saving bug! artifacts stendalon and integration 3ds max
32к х 15к
orthogonal camera
add another option to save Jpeg
I already do not have enough nerve, I have not already passed the 5 projects during these 4 months! My customers will soon be hanged. Give me back my 2.25 for 3ds max !!! with the support of Pascal
Corona no artifacts
The problem in v2 is similar, but in this case the tone mapping produces the incorrect result since it's trying to access the film buffer via a texture which has an upper limit of 4GB and your resolution exceeds that. Currently there is no v2 update planned for the near future, so this problem in v2 will probably not be fixed.
