Particles and Scatter node
Carrara (Integrated Plugin developed by Sighman)
Sighman
I'm afraid that dropbox link is not working.
Also, can you give me a zipped .csv file.
Thanks.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
tschwenke
Yes, I had to free space and deleted it unintentionally; did not realize it... sorry :?
Ok then, I created a CSV files (for the scatter node) and zipped them. I also created an ABC file with all channels activated.
The idea to zip the CSV file is quite good I think. I used zlib for it.
https://www.dropbox.com/sh/w99qikaei8ns ... xq0WF6fj_a
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
Sighman
Did you know you can load the alembic file directly into the standalone. Add a Geometry -> Scene node and you will be prompted for an .abc file. If you load the alembic you provided you will see a bumpy sphere. This is because the particle size in the alembic is set to 1 which is 1 meter. Can you re-export the alembic with a smaller particle size, say 50mm or so.
I've made some progress with the csv scatter support, I hope to release something in the next day or so.
tschwenke
I did not know that, but it's great. I tried to set a different size but it does not seem to work. OR Standlone seems to need some special channel for the size!? Can you see what channel is needed?
I posted a question in the Houdini group. Hopefully, they are able to give me a tip.
Best wishes,
Thomas
tschwenke
Hi again,
I changed the Length unit for ABC import to Millimeters, but this does not change anything. So, there seems to be no scale or size information within the ABC file that OR Standalone can use.
Oh, and great for the CSV module. I wait for it eagerly :)
Best wishes,
Thomas
Sighman
I found this link on particle support in Houdini...
https://docs.otoy.com/manuals/products/ ... particles/
Don't know if it will help with an alembic export though.
tschwenke
Thanks. However, I cannot make it work that way. The Houdini OR plugin does not use alembic; it uses the direct way. We'll see what they will answer me...
Any news on your CSV module? :)
Sighman
viewtopic.php?f=79&t=56881
I'll add some more docs after I get some sleep...
tschwenke
Hi Simon,
Great, thanks alot :)
However, I am not able to make it work. I create a sphere or a mesh object, click the scatter button in the Effects tab and load in a CSV file. Then, I see nothing... :(
I tried it with this file: https://www.dropbox.com/s/fuvn1m10zg8qq ... cle-56.csv
Best wishes,
Thomas
tschwenke
It crashes in the case of a surface replicator in the scene...
Return to “Carrara”
