[Unsupported] Blender plugin v1.xx - Code
afecelis
It's no biggie, I'm using a previous version from graphicall that's still compatible, but if I try to install it on the latest SVN compiled in Ubuntu it won't allow checking it in render addons. (It also happened with one of the latest graphicall builds under windows).
It's a shame that the API is still changing so much, it keeps breaking stuff at all levels :(
I hope official 2.57 release stabilizes this.
Regards,
Alvaro
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
yoyoz
Can you try this one and tell me if it works please?
Lionel
octanerender.v1.10.zip
(73.17 KiB) Downloaded 759 times
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
dave62
hi yoyoz,
1.10 is not workin for me.
i upgraded to svn r35708 and copied it manually to the io folder as usual but it didnt show up under render engines:(
cheers dave
edit: very strange the netrender folder in io is gone in 35708
- Mint 10 64bit nvidia drv 260.19.29/cudatoolkit3.0 intel q6600, 4gbRAM, GTX470 1,2GB
- Mint 10 64bit/ Win7 64bit nvidia drv 260.19.29/cudatoolkit3.2 amd X6, 16gbRAM, 2x GTX580 3GB
->Octane 2.44/ Blender2.5x
yoyoz
Hi Dave,
when I try to install it with overwrite I cannot select it jusrt after. However, if I save my settings, exit blender and restart it, I can select it again from the addon panel. Can you give a quick try?
The netrender is moving as an addon now. I saw comments ab out that in the commiters mailing list.
Lionel
afecelis
Just tried it out with the 35733 checkout/build and it's working fine again :D
I just need to check one thing, the scenes I export are getting a glossy material on everything, even when I change the material properties to diffuse in blender/octane's material editor.
Iĺl run some tests and get back :D
yoyoz
You should have a look at the documentation of my exporter :-)
For the material panel to export materials as you define them, you must enable 'write material into OCS' in main panel, otherwise they will be exported through the MTL file, and only the first time you export them. For getting a diffuse material from MTL export, just lower specular to 0.
afecelis
Ahhhhh great! I will indeed take a closer look at the documentation pdf, thanks a lot Yoyoz. Fixing and testing it now. Thanks for the new 1.10 version.
May I ask what changed to make 1.09c incompatible?
regards,
Alvaro
dave62
yoyoz wrote:Hi Dave,
Lionel
hey yoyoz,
thx for the tip, it works now:)
thank you very much!
cheers dave
yoyoz
afecelis wrote:May I ask what changed to make 1.09c incompatible?
When declaring a new render engine in blender, you must explicitely declare which of the existing panels are compatible with yours so you can re-use them (here we have textures, lamps, particules, etc...). The internal location of those properties have recently been renamed, this is why 1.09c didn't work anymore.
BTW, v1.10 has some extra features that are not documented and that I didn't want to publish yet, so I'll let you discover by yourself :lol:
dave62
bckt rndr ... :shock:
got to try it. lets discover more:)
go yoyoz, go yoyoz:)
thx
Return to “Blender”
