OctaneRender 3 for ArchiCAD [OBSOLETE]
s3d-weyrauch
Thanks Paul, it works perfectly without any install. You should only copy the files to the right place, as you said. I don´t need any install-package, I can roll out it with a simple batch. I don´t worry about the Appdata, I need only to install it. The licenses and the settings are tasks of a co-worker.
Your Upgrades are exciting every time, and I would use it on all of the machines as soon as possible.
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
I have updated the installers at the top of this thread with:
3.3.4.66
- Compiled with Octane 3.03.4
- Added the ArchiCAD 20 installer, and removed the ArchiCAD 17 installer
I have updated the AC20 installer at the top of this thread to resolve an installer issue.
ArchPrime
face_off wrote:I have updated the AC20 installer at the top of this thread to resolve an installer issue.
Not sure if a bug, but with ArchiCAD19 running I cannot install this latest plugin version for ArchiCAD20 (which is not running)
Octane Render for ArchiCAD 22 plugin v4.x | Octane Standalone 4.x
( 2x Nvidia 980 Ti) x 6MB VRAM | Intel I7 4470K | 32GB RAM | Windows 10
That is intended. The installer will not run unless there are no versions of AC running.
A bug has been found with the ArchiCAD 20 plugin - where proxy information cannot be saved back to the PLA/PLN. This appears to be an issue with ArchiCAD 20, and I have reported it to Graphisoft.
Graphisoft have got back to me on how to resolve this issue, and I have updated the AC20 installer at the top of this thread accordingly. So pls re-download the AC20 installer if you have previously installed that release.
3.4.0.66
- Compiled with Octane 3.04
I have also merged the STABLE release thread into this thread.
Daniel_Ward
Hi Paul,
thanks for that. Is it my imagination, or is this release a bit more stable than the last? I haven't managed to crash ArchiCAD using this version... touch wood!
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Hi Dan - it's your imagination. If you ever do get a crash, send me the dump report and I can see what the cause was.
