OctaneRender™ Standalone 3.00 alpha 2
smicha
bepeg4d wrote:
smicha wrote:
abstrax wrote: [*] Added "bump and normal mapping" option to the render passes node.
Marcus,
Am I missing something? Does it allow to render at once bump over normal? How to enable this feature? When I deactivate or active the function it's not affection the scene at all in any passes.
No, it's related to the new baking function to let you bake also this channels together with beaty, diffuse, roughness, ior, transmission, refraction and reflection... if I don't forget anyone...
Any manual/tutorial on this new feature?
RobSteady
smicha wrote:Any manual/tutorial on this new feature?
abstrax wrote: Manual
We don't have an updated manual for v3 yet. That's partially due to the fact that we are currently overhauling the documentation web site, which needs to be finished until we can publish an updated manual for v3. We will let you know when the v3 manual is available until then, please refer to the v3 new features thread and its discussion.
Draydin_r
Question: How has the sampling for PMC been improved? I have a couple of personal projects that would look great with unblurred caustics, Do the new changes improved the speed of refinement for caustics by and significant margin?
Intel Core i7 CPU 6850K @ 3.60GHz 128.0 GB Ram / Win 10 64 bit / 1x GeForce RTX 3080
remKa
I'm working on an interior scene with indirect lightning only (luminous cornices) and I have a 40% speed increase with the v3, PMC Kernel.. great stuff !
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
gabrielefx
can't wait to test this alpha with 3ds Max....
I remember that Karba released the plugin the same day of each Octane major update...
Cinema 4D, Lightwave, Modo, Rhinoceros, Daz and Poser plugins are already available.
I don't understand...
mark0spasic
gabrielefx wrote:can't wait to test this alpha with 3ds Max....
We probably don`t have 3dsmax v3 because only JimStar works on 3 plugins max,maya and blender :( they need to hire more people.
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
gabrielefx
Face_off programmer develops 4 plugins:
Modo, Rhinoceros, Daz and Poser....
Goldorak
Jim is currently developing an important part of 3.x that we are planning to introduce in Max/Maya/Blender/SU first before rolling it out to all plug-ins.
pegot
Goldorak wrote:
mark0spasic wrote: Jim is currently developing an important part of 3.x that we are planning to introduce in Max/Maya/Blender/SU first before rolling it out to all plug-ins.
Nice! I can only guess what that feature might be but I'd love to see ability to import ORBX. Or even better, ability to generate and export a scatter CSV file. Any one else care to speculate?
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
Notiusweb
Just noting with performance on 12 GPUs (Titan Z)
So I am still seeing laggy viewport UI at 12 GPU in V3 Alpha 2, and it gets less laggy as I move count of rendering GPUs down to 1.
I noticed as a comparison that in V2.23.2, there actually is also a slight added lag to the viewport when more GPUs are active in rendering. However, it is no where as crippling of a lag as it is in V3 Alpha 2.
In a nutshell, the more GPUs you use, the worse the Viewport lag (panning, rotating, zooming) gets, even if a very low memory project. Again, interesting that this bad lag is not present in V2.23.2.
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
