OctaneRender 2 for DAZStudio [STABLE] [OBSOLETE]
Moderator: BK
Sorel
Installed just now with no problems. Testing a few scenes, everything seems good so far :)
Notiusweb
Not able to access pc until later, just curious, seeing any material conversion improvements, or not just yet? :D
BTW -
This is AWESOME!!!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
This error seems only to be triggered when installing on a NEW workstation on which before OcDS was NOT installed.
If on your computer
- OcDS was allready installed with an older installer
- a OctaneRender_settings.oczdb file was created
- OcDS was activated
- registry entires were created
you will not be able to reproduce the error.
Nevertheless when you manually take steps to reset the workstation to a clear state before OcDS was installed you may be able to reproduce the error again.
I just post this so face_off has a way to reproduce the error.
I STRONGLY recommend other users NOT to do that because you may end up with a whole set of other activation issues.
If you perform only some of those steps your activation Username and Password will not be saved after you enter it and your plugin stays unactivated.
- run the OcDS uninstaller located in C:\Program Files\DAZ 3D\DAZStudio4
- manually delete the files in C:\Users\USERNAME\AppData\Roaming\OctaneRender
- use CCleaner to clear the registry
- restart the workstation
- run new OcDS installer.
- error message is triggered
I believe all the installer activation issues are fixed in the next release.
Not yet. If it's not in the release notes, it's not done.
rajib
Thanks Paul =) !
Installation ran without issue. Loaded a scene I was working on with the previous version and was able to render it without any problem. Will do further testing.
Best regards,
Rajib
Windows 10 Pro i9-9980XE 128GB RAM|4 x Titan RTX
Houdini 18.5(2020.2.1.2)|Cinema C4D R26|Daz Studio Pro 4.21.0.5(Octane 2021.1.6.83)
NVIDIA 460.89 Studio Standard
Hubby72
I really want to say i am happily surprised to at least a new version and ongoing dev communication .
You are really very welcome.
due to limited time i will skip this version but i am really happy reading here about new versions and bugfixing.
Win 10 x64 | Zotac Geforce GTX780 6GB, Gigabyte GeForce GTX 960 | Intel Core i7 3770 | 32GB Corsair DDR3-1600 | PNY 480 GB SSD |
My Blog : http://www.subwaytotatooine.de/
My DA : http://hubby72.deviantart.com/
rajib
Hi Paul,
Giving the links to 2 issues I posted in another thread.
Render setting export / import issue.
viewtopic.php?f=44&t=51398&p=255893#p255886
Opacity issue.
viewtopic.php?f=44&t=51398&p=255886#p255893
Best regards,
Rajib
RGUS
WOW... look at all those sliders and tabs... I likes it so far... just have to understand what they all do.
Thanks Paul.
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
Sorel
Ok my first issue I have found. I am unable to select a camera for animation rendering.
This is happening for me too. Was it a problem on the 2.2 version of the plugin?
Return to “DAZ Studio”
