Poser Pro 11 and the current Octane Compatibility
hiram67
confirm that the problem is also with the default image
andy.zip
(42.15 KiB) Downloaded 298 times
That scene does not work for me either. Thank you for providing it. I will investigate tomorrow.
You have the Octane Environment set to Texture Environment, so the Poser Background geometry is blocking the Octane IBL. So yes, in that situation you should Display->Guides->Ground Plane OFF, or set the opacity of the GROUND->Background to 0. I will look to see if there are some warnings to assist users know that is an issue.
Thanks again for reporting this issue.
elenacalderas
Not quite the same issue, but I'm getting good results with the sand-cloud texture of the construct. I patch in the sky texture of the background material of the ground object into the opacity channel, set translucency to 0.9 and patch the reversed sky texture into absorption. Shadow visibility of the ground geometry in this case is 1. That way, the clouds actually provide some shade by obstructing the sun.
Win 10 Home x64 / NVIDIA GeForce GTX 1070 8 GB / (Intel i7 2.8 GHz) x8, 16 GB RAM / PoserPro 11.2
hiram67
ok, thank you for the availability and the work you do
blogfather
Just bought the new Poser 11. My first impression: Superfly - no, the renderer is not very super. Many, many classes below Octane both in quality and speed.
I run the new testversion 2 plugin, Win 10 and NVidia 680TI.
So keep up the good work, please at Octane.
Return to “Poser”
