Live Viewer unrequested refreshes
sdanaher
Thanks - where's 'Links' in the interface?
Re Render Instances, unfortunately it doesn't work with light objects, so I can't use that option in my setup. I was using an emissive geometry before, but was having some issues, but I think that was solved. If I revert to emissive objects I can use render instancing.
Can you tell me if Octane handles lights and emissive objects differently (will one be noisier or slower to render then the other for example)?
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
sdanaher
Beachballing on OSX is definitely caused by not enabling render instances.
I've changed my setup and although it still takes a while to resend the scene I don't get the dreaded spinning beachball every 10 seconds.
Macos version seems %50 slower for geometry exports. But i'm working on to remove this lags. I can give a test version if you wish.
sdanaher
aoktar wrote:Macos version seems %50 slower for geometry exports. But i'm working on to remove this lags. I can give a test version if you wish.
Yes please, that would be very helpful ahmet!
lucioing
Hi!
Sometimes, it happened to me too, simply moving the mouse. But, I repeat, SOMETIMES...
L.
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
